I need some help with sizing for a Canyon CF 7.0. Anyone on here familiar with sizing? I called Canyon and spoke with one of their reps. He didn’t seem too interested in my fit numbers and just wanted my height and inseam. He told me I was a medium frame.
The bike shop that did the bike fit for me fitted me on a Cervelo P series in a 58cm frame if that helps.
I am 5’10 with a 32in inseam.
My fit numbers are as follows:
SX 135
SY 684
HX 549
HY 647
Pad Reach 499
Pad Stack 707
Pad Height 60
Pad offset 50
Saddle height over bottom bracket 761
Saddle setback 30
Drop from saddle to bars 42
Reach from saddle to bars 880
There is actually a pretty good thread that would probably provide some better specs, but I have a 7.0 in size small and my numbers are fairly close to this:
Pad Stack - 605
Pad Reach - 500
Saddle Height - 724
Saddle Setback - 3.5cm
I am pretty much pushed the limits of the small and likely should have just gone with a medium. My height is 5’8 with 32 inch inseam and I would actually like a bit more reach.
I am not really following your pad stack and reach numbers as they don’t seem to line up with what I would expect, especially the reach. I may be interpreting your numbers wrong but use mine as a general reference for what the upper limits on a small works with.
I see that you updated your reach number which makes more sense, but to me your stack puts you in the large frame size. It does seem that you have a fairly upright position so assuming that these are accurate, you look like even a medium is going to not have enough stack to get you to 707. Based on Canyon’s sizing you can see what ranges they support in each size.
Recommend giving your numbers to Ian on the thread mentioned here. I spent a bit of time working sizing out. Canyon Positioning tool had me on medium but I ended up with a small after getting feedback. I believe you can opt for a longer stem if need be, you do have to buy this though.
