Here’s the problem. I don’t have a lot of space to work on my bike outside, and because of the ungodly heat in Dallas during the summer, I wouldn’t want to anyway. Garage space is very limited, too, and so this summer, I put down mats in the upstairs office, and did all my work up there in the nice, cool, air conditioned house.
You know where this is going… I managed, to the horror and outrage of tri-spouse, to get some small (and not so small) grease spots on the office carpet.
The question is… Can anyone else who has made this stupid mistake recommend a cleaning product to get these spots out of the carpet? Is it possible, or should I resign myself to having to replace the carpeting?
All I can offer is the suggestion that you have the carpet professionally cleaned. Most good shops will tell you whether they think they can get the grease out or not.
Also, this might eliminate the likelihood that my wife could talk your wife into buying you a Computrainer.
Been there, done that. First try Resolve spot magic or Woolite oxy deep spray. If those don’t do the trick, try Opps or Goof-off. You can find the first two at most grocery stores or Wal-mart, the others can be found at the Home Depot.
Yeah… I’m not sure anyone could work enough magic to talk my wife into letting me get a Computrainer. But you’re right… I’ve now probably decreased the chances even more!
I did the exact same thing before we built the garage. Wife was a bit ticked. No problems there is stuff available to remove grease from carpets. Just drop down to the local hardware store and the clerk can help you out.
Simple Green has worked for me - plus it is non-toxic (for those who care) and has not bled any color out of anything I clean with it. I also de-grease my bikes and clean them with Simple Green.
I worked in a bike shop that had carpet in the work area and we would have it professionaly cleaned every so often but some of those citrus cleanears work pretty good also. Good luck.
When I used to clean carpet about 15 years ago we used electrical contact cleaner for small grease or oil spots. You can’t soak the carpet down because you will dissolve the backing on the carpet. Spray some on a rag and work the spot out. Make sure that you flush the contact cleaner out with some water and blot it dry. If you can get a hold of some 111 trichloroethane that is the best. If it is cotton or wool carpet it would probably be best to buy her a giant shiny diamond.
jaretj
(This message sent with 100% recycled kilobytes!!!)
For grease spots I used to used dry cleaning solvent, but it is hard to get ahold of today thanks to the EPA. How big are the spots? If they are on only one or two strands of a plush-type carpet, try snipping the strand out at the “root.” If that leaves a bare-looking spot, you can “transplant” some new strands in by sipping some strands out of an inconspicous spot and gluing them in to the bare spot with a dab of epoxy. When you get good at that, you may be able to start a new career as a hair-plug technician. This technique works well on ink, bleach, or kool-aid spots that don’t respond to cleaners.
Do these suggestions also work for cars? I have so much chain grease in the back of my SUV from being careless when I put my bike in. I have had it cleaned at a car wash place, but they either they didn’t try hard or just couldn’t get them out. Has anything worked for anyone else?
You guys have it all backwards :-). You need to ensure that you have a tri room in your house, with a home weight gym, treadmill, Vasaswimtrainer, CT and rollers. Grease is an inherent part of such a room and when your tri spouse gets upset with you, she should be banishing you to the “tri room” for a 2 hour workout to burn off excess energy and calm down.
God bless my wife as I have all of the above. Once she actually threatened to paint the room at which point I got all defensive and said that it needs to be like gym and not look too pretty :-). She gets the other 1800 square feet to decorate (and she does a damn fine job), so I get my 300 square feet down the in the basement
Wow. I need your wife to “explain things” to mine in triwife-speak. My triwife doesn’t seem to grasp the necessity of a tri room, no matter how many times I try to explain it to her. I may as well be speaking Martian to her.
Although… I may be starting to get through to her… She signed up for her first ever triathlon yesterday. Maybe I’ll get lucky and the tri bug will bite her, too, although she doesn’t seem to have the competitive spirit that I do.
