Specifically, will a Shimano Ultegra R8100 12-speed crankset work (seamlessly) in a Shimano Ultegra R8000 11-speed setup?
Will I need to change the chain?
Thank you.
Thank you.
I believe you should be fine if the crankset is all you are changing, chain should be fine as well but I’d consider replacing it and the cassette (11 speed) unless they are pretty new.
