Campy Triple -> Campy Double?
I have a campy triple setup on a road bike but its flat where I live and I can climb fairly comfortably at 300 watts so its time to change it out :stuck_out_tongue:
Can I get away with just changing the BB, Chain rings and cranks?
Or do I also need to change the Front derailure, Shifter/brake and the long cage rear derailure?
Thanks for the help
Ha, I just went the other way for my road bike.
You don’t HAVE to change the rear deraileur, but you can. You probably have the medium cage I’d guess. You don’t need to change the shift lever either. Not sure on the front deraileur, probably you can adjust the stops down to where it will work okay, but I think the double would shift better.
gavnunns
You may like the compact cranks 50-34 , they drop your top speed gearing and lower your low - from a stock double . Don’t worry about a new front derailleur the stock unit works fine .
In a perfect world the gap in between the crank rings should sight directly to the center of the cassette , a bit off is not a big deal.
As for the rear derailleur just check the chain length /slack shifted in ( Big front ring & big rear ) and ( small & small rings ) even a short cage may work . Heli
There is no need to change your shifters… Campy has a large range of micro-adjust clicks which mean you can use the left shifter with a double or triple. One of the many advantages of Campy over Shimano.
You should, however, change you derrailluers. Shifting performance will be MUCH better with a double front and short cage rear as opposed to keeping the triple der’s on.
True, a compact set up would work, and provide a similar range as your triple, but what is the point? You were thinking about a double because you don’t need that range, right? Besides, with a compact, the gaps between gears become larger and less “smooth”. You can always put a 12-27 cassette on if you think you are going to be climbing a lot.
Thanks everybody that answered the question, I thought as much but its nice to have it confirmed.
Like Artmus said, there isn’t much need for me to go to a compact crank setup as the main reason for getting rid of the triple was I don’t need that many easy gears. I will probably swap up the ders and throw on a double front rings, bb and cranks.
Thanks
