Hello
found this article interesting, showing and discussing some physio test on Cameron Wurf, before Kona 2018 :
https://www.triathlete.com/2018/09/training/lifting-the-curtain-on-ironmans-top-cyclist-part-2_334218
From the 2nd picture (4 charts), I guess we can see :
FTP : bottom left chart, at 4mmol/L : 360 or 365 watts
Max VO2 power :
- considering FTP is approx : 73 to 75% of this MVO2P : 480 to 500 watts
- 6.48 watt figure mentionned below the charts : assuming MVO2P/kg, x75 kg : 486watts
Probably move up above 500 in peak form.
VO2 probably 78 to 80 ml/min/kg here (from my calculator), more in peak form.
Interesting to see its IM race pace (approx 300w average / 305 NP) is around 60% of MVO2P, slightly below fat/sugar 50/50 calories point.
TSS for IM bike in Kona around 290 probably.
Latest CdA calculations based on its published data on Kona : slightly below .21
Calories calculations (last picture with excel file) are also interesting :
72 g/H on bike
50 g/H on Run
With 12 gram glycogen left at the end ?
For a 75kg athlete of this level, it seems to me quite low input, I though (in fact I read several time) they were more at 80g, or more.
Balance at 12g at the end seems so low.
Personally (clearly not that level) I was always trying not to go below 50% of initial glycogen stores… just in case i had issues with absorbing something at some point, have some margin… overcautious ? Am I too greedy ?
