I was changing the front end to the tri bike recently and have to disconnect all the cables to the eTap BlipBox. When I put them back together, nothing shifts anymore. So I re-paired everything again and the system is still not right.
Here is the symptoms: The BlipBox will only work with the last paired derailleur, but not both at the same time. For example, after I pair the BlipBox with the RD, then the -/+ buttons will move the RD like it should. Then I pair the BlipBox with the FD, the FD button will work as it should, but the -/+ buttons will no longer move the RD. it’s like the BlipBox “lost†the pairing with the RD (because the light won’t flash when the -/+ buttons are pressed). And vice versa.
Anyone has run into something like this, and more importantly, any suggestions to fix it?
Yes, but unfortunately I cannot remember what I did to get it all sorted out. And like you I had it all paired previously.
I’m trying to think what I did, but it is just not coming to me. I think I was not going through the sequence of the pairing correctly even though I was reading the directions. I remember watching the YouTube SRAM video many times before I stumbled on the correct sequence in the pairing process. I bet if I had to disconnect the cables now I would be going through the same thing again.
Thanks for the help, I followed the sequence and got them to work. I was thrown off by the FD going into flashing quickly only momentarily and then going dark - I thought it was not in paring mode anymore.
anyone know what the bolt size that threads into the mounting hole on the back of the standard eTap Blip box? I want to mount it using this threaded hole.
thanks
