Calculating rTSS for track workout
Anyone have a way to calculate a rough rTSS for a session of 6x800s? I turned off the GPS on the garmin because it gets all weird on the track.
If you can find out your AVG pace for the ON’s and find the % of LT pace it is, then square that number, finally multiply it by the number of hours you were riding! Same thing if you need it for bike TSS too someday.
So say, pace was 4min/k and your LT was 4min/k = 100% of LT. So take 1 ^ 1 * .5 (say it was 30min) and you’d get 50TSS!
I’d say that might be easiest? You can do hrTSS too, using the similar formula.
Maybe someone has an easier formula?
IIRC for RTSS they basically do what you’ve outlied but then bump the result up by 10%.
Hugh
Perfect! I’m not much of a numbers person, but I figured it out. Thank you!
6x800 @ ~10 seconds under 5k pace came up with 38rTSS – seem reasonable? My threshold pace is 6:40/mile and I was coming in at 2:53 for each 800. 17.3 minutes of intervals.
Seems about right as only 6 x 800 isn’t very “long” in duration or length. As Scguy said above, maybe even add 10% to that? Cheers
Depending on how well you paced them, you could construct a CSV file that WKO will read and do it that way.
You could also do somethign similar for track workouts you do on a treadmill.
Not that I would ever do anything like that or have a spreadsheet template that makes it a 5 minute job to create a wko compatible file.
http://home.trainingpeaks.com/blog/article/running-training-stress-score-rtss-explained
This is basically it although not identical to the method TP uses. Considering you were on a track it’s safe to assume that the difference between average pace and NGP is irrelevant. Just remember you need to use the total time and total distance not just the 6x800 efforts.
If you paced every one pretty consistently, I’m getting an IF about 1.12 and rTSS of 38.8 over those 6 intervals. Add in the jog recovery (if you had one) for an overall TSS for the run.
I paced them pretty consistently, at least I think so – fastest was 2:50 and slowest was 2:56. 1.75mi warmup run to the track @8:45 pace, 5x400m jog recoveries at 2:10, 1.75mi cool down run home @8:45. I guessed and came up with 91.3 rTSS (factoring in 10% increase for run).
Granted, there’s no way to perfectly quantify a TSS score, but I feel like it’s a good estimate.
Seems like a very good estimate based on the intervals, recovery and warmup/cool down which totals a bit over 1 hour of running.
I’m calculating that out to a rTSS of ~80. 30 combined for your warm-up and cool-downs, 38.8 for the intervals, and 11 for the recovery jogs between them. Since run TSS is a different value than cycling TSS, though have a similar calculation, I don’t add the extra 10% in. TSS is based on a maximal 1-hr ride, rTSS is based on a 1-hr maximal run, so it’s already accounting for the additional weight bearing nature or running.
If you’re looking at a comparison between running and cycling TSS, then I can see a factor of 10% added for the run since running requires more energy expenditure and will have a greater overall affect on fatigue for the same duration. So if you’re planning a specific weekly TSS for combined training, then adding 10% on top makes sense.
Intersting about the 10%, but I agree with you. Everything technically is based off the 60min effort. Probably why it’s so hard to do Swim TSS!
In GoldenCheetah v3.2 the manual workouts for running or swimming allow the entry of time and distance for work and rest intervals to generate samples assuming even pace on each one, these workouts have GOVSS/SwimScore automatically computed and they can be uploaded to TP to have rTSS/sTSS.
Here are some screen captures about how this simple feature works: https://groups.google.com/d/msg/golden-cheetah-users/dvzyg-4fhP4/rIlvlLKIgggJ
Did this workout back in March, so went back and looked at it for you. I actually did it on the road on a slight downhill, rather than the track.
W/U: 6 laps
M/S: 6 x 800 at open 10km effort/pace with 2 laps easy jog as rest
C/D: 20mins Easy
Here is the file: http://tpks.ws/x4Uk
84.1 TSS / 1h13m run time
I went to a seminar run by Hunter Allen last year and he said that rTSS gives a score of 100 for a 45 min threshold effort (his explanation was that to account for the additional stress on the body from running 45 mins of threshold effort was equivalent to 60mins on the bike), so I’m not sure whether he was incorrect, or that link is perhaps out of date?
TP uses a proprietary formula to calculate rTSS. There are a few different opinions on manually calculating rTSS.
Awesome!
I will definitely be using this when I get home. I paid for TP this year, but I might just make the switch to GC soon… I tried a few months ago, but it just wasn’t as seamless as TP yet.
