When buying replacement bolts, I see the convention of M5, M6, etc. Does this mean a 5mm, 6mm, etc allen hex fits? This assumes the thread per unit length is standard.
As the poster before me said, M6 refers to a 6mm major diameter bolt, however, I have found that bike companies often use modified or non-standard bolts. It’s probably best to take your bolts to the local hardware store (not Home Depot) and match them up. I have found that Ace or True Value (in the US) has great SS hardware selection, HD does not.
