Assuming my burning throat is from running in cold weather (around 60 degrees here), what do you guys use to solve this problem? Cough drops? I didn’t use to have this problem but as I got older, it seems to bother me as the weather gets colder and running at nights.
60* is cold?! I’d KILL for 60* weather, I’m in Maine and it was high 20s here yesterday. Wimp
How is the humidity where you are? If the air is dry, you will have more issues breathing - something about water loss… yeah, try cough drops, and keep drinking water while you run.
if the only option is running in shorts and a t shirt, then it’s not cold.
that said, it probably is the dryness of the air, not the cold that is bothering you (or the ash?). In the cold, dry air here, you can cover up and breath through something, which will collect water from exhaling, and thus humidify the air coming in. Helps me. Though I think you might look funny in 60 degrees.
Though… it could be exercise induced asthma, or other things… check with a doctor if it persists.
Thanks everyone that replied. 60 is cold over here in So. Cal. At least for me. I think the scarf idea is a no go, I like the gum one but I’m worried about the warning you gave me about choking. Maybe it’s a fluke because of the air quality but I’m certain I have this problem every winter.
Lol! I live in Pasadena. I’m sure you are familiar with the city but it’s hot here (in the high 80s), not like the beach areas where 60 is probably the norm. I don’t think I can live anywhere that is 28 degrees. I guess if my job demanded it but it would really be a last resort. Now that I think about it, 60 is not that cold…maybe I’m sick.
When I ran at Western State (Regularly in the minus for the AM runs) a lot of us wore the lower face ski masks. Your perspiration and breath make the mask wet, and keeps the inhaled humidity higher. But if you’re wearing a mask at 60 degrees there is something seriously wrong with you.
