Caveat: Not a doctor, don’t play one on TV, but train like a mofo and have experienced my share of “tingling, sore, hurts, ouch” etc.
Before running (well, maybe hobbling, in your case) to a doctor:
What have you done with your training? Biking a lot more? Different bike position? New shoes? Worn out shoes? Running a lot of hills? What?
Do you stretch? Do you get massage?
The area you are describing is obviously your quads, and it COULD be a nerve related issue which would point to your back, but need for an MRI may be premature.
Sounds like your psoas/rectus femoris, which are the hip flexors. Psoas goes up your back, which is why it’s suspect. If you don’t stretch it or don’t know how to, it can cause problems in bikers or runners or even swimmers. Same thing with tight glutes, weak adductors or imbalance of quad strength between inner (VMO) and outer (vastus lateralis). Any of these things can cause pain in the quads referring to the knee.
I’d try a few things before going to doctor: gently stretch your psoas. Several ways: kneel on one leg; other in front as if mid-way through lunge; pigeon pose in yoga (difficult if you haven’t done it), stand up and put one foot on table. Do you feel anything? Does it hurt? Try a quad stretch where you lay on your stomach and grab one foot and pull the leg gently towards your back. This stretch works better on the rectus femoris than the usual standing quad stretch.
Next, check for trigger points in your rectus femoris, which is the large meaty, central part of your quads. The trigger points are usually right up near the tendon area. Hunt around with your thumbs. Any tenderness? Hold for maybe 30 seconds and then relax and massage around them. Better yet, go get a sports massage.
If you’d like, PM me, I have a whole set of stretches that target psoas/rectus femoris/piriformis that seem to work well to keep me in good condition and others have found relief for various things.
Trigger points cause symptoms that mimic nerve issues. Trigger points come and go in athletes. It’s just a result of the muscular stress we place on ourselves. But having them doesn’t mean the muscle is injured or you have nerve damage. But if you don’t take care of them by working them out by stretching, trigger point work, etc., they can turn into much larger problems.
