I know there’s already a thread on the new Canyon Speedmax Disc but I wanted to direct the conversation to a specific topic: Between the Aerobars hydration, and specifically its absence, on the newly announced tri bike.
Until now, BTA (between the aerobars) hydration systems were sold as something that not only improved hydration but also carried real wattage gains and are something that top of the range triathlon bikes have had for years, whether they came with the bike or were added with retrofitting of aftermarket products.
Triathlon bikes sold with integrated BTA systems include the previous Canyon Speedmax, Scott Plasma, Giant Trinity Advanced, and more.
Even the new Scott Plasma 6 has kept an integrated BTA solution despite also having a “fuel cell”.
Now, Canyon has decided to go a different way.
The new Canyon Speedmax Disc claims a 9W improvement over the Speedmax CF SLX. While the Speedmax CF SLX (rim brakes) has an integrated BTA solution, the new Disc versions (CFR and CF SLX variation) cannot support a BTA solution at all and only allows the use of the integrated “fuel cell”.
I’m curious then why is that so? Why did Canyon decide to create something that cannot use such a common solution?
Were the speed gains not that big after all?
I’m looking to hear people’s thoughts on the above.
As far as I remember an interview of Canyon’s engineer, Wolfgang Kohl, he said that the BTA solution from the previous model had following downsides: 1) increase of the exposure to side winds (bigger surface) - the current solution in the frame reduces the side exposure to crosswinds - 2) center of gravity of the bike is higher with a BTA - a disadvantage for the handling of the bike.
Interesting topic, I was almost ready to buy this bike and waiting for it since a long time. I used a Camelbak backpack with such kind of bladder in the past, and it was a PITA to clean. Plus I am not completely convinced of how convenient/easy it is to replace the bladder in the frame after removing it. Plus the increased price. Now I am hesitating a lot. Not interested in the CF for various reasons.
Problem with these in frame bladders is the location of the refill port. I find it way harder to refill via a valve behind the stem where my legs are moving when cycling compared to a valve in front of the stem.
The crosswind argument is a poor one. You assume people buying such bikes can handle a bike. If not they should spec them with low profile front wheel as well.
Both Canyon and Scott’s new bikes look pretty from a marketing point of view but practicality seems to become an issue with today’s so called super bikes.
Impressive designs but so far I am not convinced about daily usability.
Sam
Interesting topic, I was almost ready to buy this bike and waiting for it since a long time. I used a Camebak backpack with such kind of bladder in the past, and it was a PITA to clean. Plus I am not completely convinced of how convenient/easy it is to replace the bladder in the frame after removing it. Plus the increased price. Now I am hesitating a lot. Not interested in the CF for various reasons.
As a Shiv Tri (rim brake) owner I can say with some confidence that the Canyon’s in-frame bladder will be a PITA.
The thing that wonders me is why they so explicit say that it is tested only with water. Like almost saying / reading between the lines; ‘shit, that valve gets stuck when it is sticky from sportsdrink so since we are online only and we have to ‘protect’ ourselves from discussions on issues with the use of sportsdrink after the bike is sold’. So we just say it is only tested with water. Or that cleaning is such a bitch that we just say water only use.
It is so hard to believe that if you put that much work into a integrated hydration system and then don’t test it with sportsdrink only with just plain water. What they say is that they didn’t test it with sportsdrink due to all the differences in composition it was impossible to test it with sportsdrink. It sounds to me like either they know or expect that some sugary stuff can cause issues.
It just feels a little weird to me with that hydration system.
Installation is not the same as cleaning I’m curious how they managed to avoid the patent of Specialized on this. Can’t imgane Spec would sold them a license for it.
There’s nothing to clean if you fill it with water and concentrate your preferred carbs in the gel bottle, as intended. If you want carbs from course, theres also the BTS.
Jeez, can’t make everyone happy, I guess. Give people a gel bottle, BTS, and a bladder, they want more. Give them a P5x and its too much.
750ml is plenty water to make it to the next aid station, there are other places on the bike to put carbs, and there’s always the option to add BTA if you want to go 300km without an aid station.
This raises a few questions:
By gel bottle you mean on the down tube?
How would you set up the BTA? It really looks like it wouldn’t be compatible given the “mono” aerobars
if you decided to buy it what would be your preferred hydration/nutrition set up?
Owning a shiv s works bike with a bladder the big thing is you never know how much liquid is left after first using it. I have run out a number times during a race. I did away with the bladder went to a BTA that is clear.
Come on, If I get a bike at this price setting I don’t want to be limited to just plain water to use my hydrationsystem.
Jeroen.
Absolutely - but for training you can put bottles on the bike and use the bladder with sugar for race only maybe, making it less of a pain to clean?
I know lots of people race with mostly to all liquids, so it should be something they are cognizant of. Going to the rear cage for calories isn’t the best option - especially for aero!
Jeroen
Generally, design patents only last 14 years. When did Specialized submit that patent.
It takes a whole lot of money to get an extension to a patent.
Within SHIV Disc development, ride quality was a big area of focus. Generally speaking ride quality of tri bikes of old was less than optimal.
Keeping the weight in the front end down was critical, and we didnt want the users selection of BTA or no BTA have a large influence on the bike performance.
A lot of heat what thrown at our bike with the rear hydration, but it is still optimal in nearly all regards but re-fill. We always expected that refill would be done at the BTA on an as-needed basis but we also have learned even more from our atheletes since that decision.
Not have 1L of fluid on top and/or in front of the steering axis is a big deal
The SHIV Disc does not have a BTA Solution per say, but it does have a custom BTA mount that can be used to add bottles for long course, or holds the PC for short course. This eliminates a lot of unnecessary weight and improves the ride
I have Scott Plasma 6 and unlike Speedmax with valve that needs to be pressed, Scott has lid you flip open. the opening is big enough that bottle nozzle goes inside…this way you don’t spill at all. Did it number of times already and it works. Speedmax solution looks sleeker with the valve but to your point it is hard to keep bottle still while pedaling and pushing the valve down at the same time to dispense the bottle
Yup. I have the new speedmax and yup, I find installing it a pita. Also when filling, has to be installed correctly or won’t fill…and filling on the go, not the easiest.
This is old thread but I still want to share my experience. Last year I looked to get new Speedmax CF SLX and after several delays in US I went with Scott Plasma 6 RC. Both have in frame integrated hydration. I used Scott at 3 Ironman races in 2021 and found its hydration being superior over Canyon bladder. Mainly install, cleaning procedure but also refill on the go. Scott has plastic mold resistant container easy to clean with bottle brush… Also installing it is very easy rather than fiddling with bladder. Canyon told me that they expect riders to use bladder with water only. This is no for me. I cary nutritions on the bike and take water from aid station to drink and throw remaining bottle right away.
Also refill is easy on Scott as you lift the cap and opening is big enough to fit in bottle and squeeze without pressing down which is required for Canyon with the valve solution. Hard to keep pressed, while squeezing a bottle and riding at the same time…
