Ok, I am coming back to this story as a recap and for future reference for people who have broken toes and too make them optomistic, this is what I did. The following was a response to someone whose daughter has turf toe, it made me think of how I would get back to my recent post of a broken big toe that I got a little over 6 weeks ago. Before that, I would like to say that if anyone has a broken toe they should read the rest of this thread, and see there Doctor (duh) for even more information. I had an intra-articular break of my big toe at the proximal phalanx, aside from eating healthy (plus, no soda, alcohol), taking supplements - vit c., bromelain, minerals (w/ calcium), vit. D, omega 3’s, and eating a good amount of yogurt, broccoli, pineapples, bananas, this is what I did…
Ultimately I would do what the doctor suggests, physical therapy, taping, or whatever. Just had a broken big toe, and came across a lot of turf toe wrapping in my spare time. Just due a google search for turf toe wrapping, and turf toe wrapping with k-tape (kinesio tape). Also, if you go to a therapist, make sure he is doing stimming and ultrasound. You can buy a great TENS stim for under $45 that is battery operated. I use mine on any injuries, even with my toe fracture. Doctor said with the type of fracture, I couldn’t run for 6-8 weeks, but since I stimmed, Iced, heated, lightly Ice massaged it, wrapped it every day (with 1 ultrasound a week), when he re-x-ray’d it 4 weeks after the break, he said I could have started running a week earlier. So in effect I cut healing in half. I decided not to run though for another few days, so that it could heal further.
Ice and heat everyday - no more than 15 min at a time of each. Best way to do it, put electric stim on, and while stimming heat the foot for 5-10 minutes, take heat off (leave stim on), and immediately ice 5-10 minutes. Do this 2-3 times a day. Also, ice massage (with stim off) occasionally. The way you do this is to put water in dixi cup, freeze, then cut out bottom and massage area. Make sure she stretches toe after initial healing, and perform exercises. Stretches include 1. calf stretching, 2. tibia stretching, 3. all toes dorsi flexed, 4. all toes plantar-flexed, 5. than individual toes dorsi flexed and 6. plantar flexed, 7. assisted toe seperations. Exercises include 1. curling towel on floor with toes, 2. picking towel up with toes, 3. using band as resistance to dorsi-flex (plus inverted, everted), 4. using band as resistance to plantar flex toes (plus, inverted everted), 5. using band as resistance invert and evert feet 6. seperating toes (toes do all the work, no assisting). When she gets stronger - 7. calf raises - regular, inverted, everted, one-legged, 8. jump rope jumps (without jump rope) varying height and one/two legs.
Good luck,
Chris
Extra: As for what I did with taping, I first wrapped big toe at break with k-tape cut half the width (no tension on tape), then I cut k-tape in thirds (of width) and at about 4 inches, I put one-third on top of toe (with no-tension starting on toe, 1/3 tension between toe and metatarsal then no tension), I repeated the previous action for the bottom of the toe, and the arch side of toe. Then, I started buddy taping. I used a non-sticky, self adhering tape, wrapped toe once (without tension, don’t want to cut off circulation), then put cotton ball between big toe and second, than wrapped once around that and ended at the top of big toe. Every time I took tape off, and put back on (for therapy), I changed direction of buddy tape wrap as to not torque/twist toe in one direction.
As an aside, cotton ball, only needs to be for a big toe break. Other toes, you just buddy tape.
