Brake squeal and vibration
Need some help with rear brake on my Cervelo P3. I have Magura hydralic brakes and use a 2013 Zipp 404 650 Firecrest wheel for racing. When I apply the the brake I get a shutter and loud noise. Changed from Yellow Swiss stop to Envy, no chnage. Checked toe in, no change. Lightly sanded the track and smoothed with fiber pad, no change. Now what? Thanks for any help
bump
Something is wrong with the wheel, not the brake.
Check to see if it is true, the skewer it tight, the hub isn’t worn, etc. Lift the bike and grab the wheel and try to move it It shouldn’t move. I bet yours does for some reason
Sounds like the brake is pushing the wheel out of alignment.
Jack thanks for taking the time to respond. .ill check it out.[
