I’ve seen some threads on here but can’t find them now. Anybody have the links…or suggestions / pictures of a good setup. Any thoughts on the Profile Design HC Mount…looks effective and fairly cheap at about $20.
I used zip ties to secure a Bontrager Race Lite cage between the aerobars. The bottom of the cage rests on the base bar for added stability. Absolutely solid, no launched bottles, love it. Pic below (and the cage really isn’t crooked or slanted… that’s just the perspective from the cell phone camera).
When this craze was still in its infancy, I bought a device from Minoura for just $6. It works great as long as you don’t have your aerobars in their narrowest configuration.
Now XLab offers something for $45. Ridiculous, but I guess it isn’t the first case of triathletes paying way too much for something. Even $20 for the profile thing seems too high. Just look at all the zip-tie set-ups. They’re cheap as free.
don’t know about the HC mount, but you really only need a bottle cage and zip ties. It does depend on how close your bars are together (the closer they are the better they support the bottle)
here is a pic of mine, two zip ties is all that I used and it works perfectly
My setup looks EXACTLY like this including the location of the Garmin. Heads up to you though - I was racing 2 weeks ago and the rear derailer cable worked itself under the Garmin Quick release and it went flying while I was going 40mph downhill. It was an expensive mistake!
dang!@ thanks for the warning, i will double check my cables tonight. I think they are fairly safe and tucked out of the way, they are zip tied , yes more zip ties :-), together behind the stem before they go into the frame. It keeps them in place. You can sort of see the zip ties in the original pic.
here is the front view
Did you stick with the 305 or upgrade to something else for the replacement?
Thanks again
I’m not sure I understand what they are doing with the cut up tube…?
Protect the bars from the cage. Keeps it a bit softer for less shock onto the cage as well.
X100…
Tom D did a write up on it… I ordered a couple and absolutly love it… made laying out the cockpit of my bike way easy… ( I had the xlab carbon thing… PIA)
