Was perusing the bontrager white paper which details their new D3 lineup as well as the additional info on the site (http://bontrager.com/features/aeolus). It seems that the clincher 9 is possibly more aero than some discs according to the data provided on the site.
It appears as though the D3 lineup are very fast wheels, but is this even possible?
No, a disc will be aerodynamically faster. But, some discs are really flexy and that can be a big issue. So I’d still be somewhat picky on the type of disc you get. But in general, 90mm (88mm for zipp) are pretty close to discs in low yaw angles. It is when you get the side winds that the differences really appear.
I would typically agree but check out the plot of the D3 9 with R4 tire in the link I provided above. Of course you cant really compare numbers across different tunnels and even different visits to the same tunnels, but it definitely looks better than the data for the FLO disc and the HED Jet.
One big difference there could very well be the tire. Its pretty widely agreed that tires and the way the fit to the wheel can affect there aero performance greatly. Another thing with rear wheels and disks is that stand alone wheel test are not the best as the way a wheel reacts to the frame has an effect of there aero performance as well.
The graph looks phenomenal, but I’m not sure I could buy wheels from a company that espouses this:
Shallower is better.When you run shallower wheels, you reduce weight, decrease the watts required to climb, increase acceleration out of corners, and improve handling on windy days
“shallower wheels increase acceleration out of the corners”
That’s true, all else being equal (including weight and aerodynamics), as shallower wheels will have a lower moment of inertia and require less energy to spin up, hence higher acceleration. But the effect is very small.
I was in the tunnel yesterday with this wheel in the tubular version along with some others and I was shocked how they performed against my Lightweight Disc. Very different results when I was on the bike vs me not on the bike with the different set ups. The conventional ST wisdom certainly did not apply to me.
Details?! Please clarify that next to last sentence.
I will post details soon. I am still trying not to believe the numbers. The Reynolds RZR 92.2 on the front and rear tested out the best for me.
The disc and Razor were similar at 0 degrees but then the Razor pulled away quite a bit after that.
Again, the numbers were better with me actually on the bike. With me off the bike, the disc was better. The engineer folks I spoke with said this is the case for every person they have tested.
I’ve had the exact same results in the tunnel - various discs were only superior to the 808’s and Reynolds 92’s at 0 degree yaw. Unfortunately, you’re almost never at a 0 yaw.
You’ll have better luck convincing the ST crowd that the earth is flat, than convincing them that a disc isn’t always faster. I wouldn’t even bother trying, just prove it on race day.
Interesting. Things you might want to include when posting details:
Which tires (brand, model, width) on each wheel (and what is the width at the brake track of each wheel), which frame (how well did it fair the rear wheel), and how many repeats of each setup, especially with you on the bike, and what did the variation look like between repeats? Also, rotational drag is likely a bit lower on the disc so this should be taken into account when judging the whole system’s drag.
It appears the Bonty 90 has a bit deeper rim than the Zipp 808 Firecrest at 81mm (Zipp website: http://zipp.com/...t---carbon-clincher/# ) with at stated rim depth of 90mm.
That may contribute to the excellent stall characteristics of the Bonty 90.
ST’s Greg Kopecy wrote some interesting articles on the subject:
I would love to see the windtunnel results that show a disc is slower than a 90mm rear. Especially an RZR, which does not use a blunt nosed rim design, but instead a sharp knife edge style rim.
I will say that it is not just the Slowtwitch crowd that believes discs are faster. If you look at even track racing events, especially with countries like Great Britain and Australia who have spent sizable money on aerodynamics, it has always been conventional wisdom that a double-disc is fastest. The idea is obviously that spinning spokes will always create more turbulence from anything but exactly zero degree yaw that a solid disc would.
Now, someone smarter that me could probably model this on a computer and try and show that at a certain spoke length (ie very short, with a deep rim), that a small amount of extra turbulence near the center of a wheel would actually clean up the airflow on a bike with a rider, thereby making it faster than a disc.
Well it’s not just the turbulence of the spokes, but also the idea that, at higher yaw angles, the disc acts like a sail. All this talk about discs being faster only at zero yaw is odd because I always thought they were best at relatively high yaw.
On another note, I’ve owned a set of Bonty 7 D3 clinchers for several weeks now. Probably have about a thousand miles on 'em (training for B2B relay – 112 mile TT). When I got 'em, I took a set of Hed Jet 6 C2s off my Shiv TT and put the Bontys on. Haven’t taken 'em back off. This will be my third time doing the B2B relay. I’m training hard, but I’ve trained hard every year. The Shiv has been a nice bike, but I own a P4 that has been my go-to race bike. But the Shiv TT with these Bontys has been a whole new ballgame. I’m setting PRs on route after route and ride after ride (and I’m about to turn 57, don’t see many PRs anymore). I asked Carl about a hilly half-iron relay I have coming up and if he thought I’d be better off going with a disc or just sticking with my 7 on the back. He said go with the disk. I’m not so sure anymore. I put wheel covers on the 7 today and rode that hilly half course. I rode it two weeks ago without the covers. Seemed slower on the hills and faster on the flats with the covers. Duh. Net net, it seemed like a toss-up. In the end, speed about the same.
If I could get an Aeolus D3 9 to put on the rear for race day, I’d be all over it. Not available yet. Bummer!
Qualitatively, my 7s are my favorite wheels I’ve ever owned (and I’ve owned a LOT of nice wheels).
Super interesting that you both saw similar results with those Reynolds. I had written them off since the trend has been towards the more blunted shape.
Definitely looking forward to 7summits detailing his findings.
