So last year I raced IMLOU on the boardman air tte 9.8 with reynolds aero 90 wheels. So the issue is they didn’t truly fit my frame because my brake pads scrubbed the wheel the whole time, just too wide at 26mm. Basically filed the brake pads down to the nub just to get it to roll 80 dollar brake pad. And I see all these other same bikes as mine with zipp disc which figure around 27.9mm fit. What am I missing? I want no scrub, is it that I have a bad bike mechanic or what? I need some help bad in getting some wheels at 80 mm or deepe. No price range or just general advice on setup?
The Boardman rep to me:
…simply by removing the spacers located behind the pad and putting them onto the back of the bolt we increase the potential gap from 25.96mm to 33.96mm
If it is the brake tension that your chap is asking about this is done with a 15mm open ended spanner and a 5mm Allen key working together like an old school cup and cone.
I have a similar problem with the TM01 with having wide wheels. I ride a Super 9 clincher/404. The Zipp disc is actually 26.4mm, not 27.9. If you are looking for a better wheel setup and price is no issue I would look in Mavic wheels.
OK so he was right something so little as the little washer looking spacers on boardman bikes and bmc tm’s has to be removed on both sides. It is right before the brake pad just take it off.
I was at TriShop yesterday looking at bikes and when we discussed your bike they mentioned that there is a problem with the cable and brake workings where they don’t apply equal pressure to each brake lever when opened to far for ZIPP or HED Plus wheels. As a result, one lever almost always rubs. They were going to have a conference call with Boardman reps this week. They tried to dremel some parts of the carbon inside the fork to potentially help with more room but it did not work. Plus there is something going on with the cable.
Yes, I removed the spacers, but not only that, for my rear because the super 9 is so wide I sanded down my pads AND I took the screw off the brake calipers. so technically if i held the rear brake down and rolled backwards I could potentially pull the pad out of the caliper. it was the only was I could make it fit.
So what do you have the BMC. Boardman said I should be able to put them in with the screw.
Hi, were you able to fix the wheel rub? I have the same issue with my tte
Got some new SwissSide Hadron 800+.
Rim width is 23 mm. Fitted the brake with MTB low profile V-brake pads.
!(webkit-fake-url://2C73D92E-721C-4AA6-9B49-BDE446417BD1/imagejpeg)
