BMC TM02 + Ultegra Di2 battery mount - help!
Been a lurker for a while, so a warm hello for this, my inaugural post on ST.
I’m currently building up a BMC TM02 with an Ultegra Di2 groupset and have stumbled across a curious issue which I was hoping someone here might be able to help answer. I can’t seem to get the Ultegra Di2 battery mount to slip through the hole for the “battery cavity” in the frame.
LBS owner has suggested two options, neither of which is ideal: i) mount the battery externally; ii) ‘snap’ off part of the locking latch on the battery mount, which slims the battery mount down to a point where it fits through the hole.
Anyone come across this before and if so, how did you resolve it?
When I say “battery cavity”, I’m referring to this:
http://img690.imageshack.us/img690/4206/batterycavity.png
Strange because you can buy a BMC TM01 with Ultegra Di2 group. And I am pretty sure that the battery side behind the flap.
Have you installed the battery as illustrated here ?
http://i154.photobucket.com/albums/s269/Tillquist/Weight%20Weenies/Skaeligrmbillede2012-12-28kl101427_zpsca52df32.png
Thanks for the suggestion. However, I’ve tried every angle and direction imaginable (including that specified by the manual) - still very much like fitting a square peg through a round hole. Worth also noting that the battery mount illustrated in the above images is probably a Dura Ace battery mount (as wire runs directly into the battery mount, rather than plugging into a female E-tube port), which I can only assume is marginally slimmer than the Ultegra Di2 E-tube battery mount.
Exactly why I thought I’d have no problems with the build. My guess is that BMC’s using Shimano’s 2013 SM-BTR2 seatpost battery though…
All sorted now! LBS just informed me that they managed to get in by jamming it through - the Jeremy Clarkson method… “POWER!!!”
Just to end this thread on a bit of a high, some bike pr0n:
http://img217.imageshack.us/img217/8788/72cc1157jw1e05y6wr8a5j.jpg
congratulations and happy new year!
I have Di2 on my TM01 and it does take a bit of force to get the battery in, and you have to do it at a certain angle. Beautiful bike though; the color scheme is great in your picture. Enjoy your new ride!
What does your final build look like? I’ve just bought a TM02 with 105 that I plan on stripping out and replacing with Ui2. Just waiting on those dual controls to come out. Any other roadblocks?
Since someone’s interested, I’ll take some shots on Sunday when I pick it up from the LBS. They’re finishing up with the build tomorrow (some E-tube wiring bits which we were waiting on just came in today). Specs are as follows:
Frame: BMC TM02 Medium-Long Silver (2012)
Fork: BMC aero road fork, pure carbon, with subA
Base bar: Profile Design Ozero
Aero bars: Profile Design T2 Plus
Groupset: Shimano Ultegra Di2 (172.5mm 53/39 crank) // Wheels Manufacturing BB30 adapter & bearings
Saddle: Fizik Arione K3
Brake levers: Shimano TT78
Wheels: Mavic Ksyrium Equipe
Not quite the beast Tillquist has, but this is my first TT bike…
Roadblocks? Aside from the above “roadblock” (more a learning point), none really. I did buy Shimano’s E-Tube Internal cable set, which came with the long bottle cage battery mount (SM-BMR1-Internal) and this doesn’t fit into the battery mount mounting point in the frame, so we cut the mounting plate down to size. I believe the SM-BMR1-Internal / SM-BMR1-External / SM-BMRS1-External battery mounts are all identical, with the exception of the length of the mounting plate.
Just note (in case you haven’t already, although I’m sure you have :slight_smile: ) that if you’re planning to run both the aero bar & brake lever shifters, you will need the SM-EW90-F 5-port junction box. Make sure you have the wiring schematic very well planned out because I found this bit goodness awful. The fact that Shimano gives their parts cryptic names like the SM-EW90-A / SM-EW90-F / SM-EW67A-E hooks up to the SM-JC41 via an EW-SD50 doesn’t help either. If you need something to help you decipher the Di2 nomenclature enigma, this would be a good place to start: http://dev2.infocaster.net/tech-info/
Thanks a lot pal. Early days for me, but I appreciate the advice!
Which aerobar shifters and junctions are you using? I have a TM01 build (photo) and waiting for SW-9071, ST-9071 and SM-EW90-F to finish it with brakes and gears.
Got back from the LBS at dusk so I couldn’t take any good shots in the absence of decent lighting. Will sort something out for next week.
First impressions are how smoothly the bike rolls on pavement.
I’m using SW-R671 shifters with the SM-EW67A-E junction. I did consider the SW-9071, ST-9071, SM-EW90-F route, but the price differential I was quoted was about CNY5,000 (about $800) - maybe something for the future if I’m unhappy with the current setup.
Does the SW-R671 plug straight into the SM-EW67A-E? I’m getting a bit nervous that all the necessary D-A pieces won’t be available before TT season starts in April and that might be a backup plan if something goes awry.
No, since both the SW-R671 and the SM-EW67A-E have male lead wires coming out, you link them up with a SM-JC41 (or a SM-JC40). So the cockpit wiring goes SW-R671 → SM-JC41 (or SM-JC40) → SM-EW67A-E. Leaves you with loads of wires to deal with in the end, 90% of which we’ve shoved inside the frame - I don’t know how the TM01 would fare here as the front end’s completely different.
All the functionality of the SM-EW67A-E (battery meter; rear derailleur adjustment) is maintained.
Final build pics:
http://imageshack.us/a/img525/6667/img8518b.jpg
http://imageshack.us/a/img252/7027/img8530d.jpg.
Nice build :slight_smile:
Very nice, I like the white theme.
My bike says hello :slight_smile:
Installed the Ultegra Di2 battery mount on my TM01 yesterday and it went in smoothly, no need for power at all. Might be a TM02 specific problem or some tight tolerances on your particular frame.
What size of battery mount did you get? They come in three sizes…intermediate, long, short. Thanks in advance!! Yoeri
What size of external battery mount (SM-BMR1) should I get for my Tm01? Intermediate, short or long? I am guessing short based on your experience?
Also what length of wires did you get for the internal routing?
Thanks in advance!!
Yoeri
