Hi folks,
For those with BMC tm02s, how tall are you and which size do you have?
Thanks a lot!
Hi folks,
Thanks a lot!
2015 BMC TM02 - Medium Long
I am 6’2"
I’m 5’9" and have a 2017 BMC TM02 medium-long. Depends on leg to torso ratio as someone the same height could easily fit on medium-short.
I’m 5’-10" and I also ride a 2015 TM02 size medium long.
170cm about 5’7 I think. Short legs.
I just got a 2017 tm02 in a small.
I think the reach is longer on the small than on the medium-short
interesting.
i am 5’9" and have a 31.5" inseam and my LBS sold me a M-S TM02. got it fit and all but first ride out on the roads was nigh impossible due to instability on the front end - knees were practically coming up to touch my elbows and wobbling the front wheel with every stroke.
did i dun goof?
interesting.
did i dun goof?
A fitter put me on a medium long tm02 with a 130 stem and I could barely keep thing that in a straight line. The handling was awful and I just kept telling myself it was normal because it was my first true tri/tt bike. After the fork steerer cracked and they replaced the entire frame, I went to the large with a 110 stem and it handles great. No adjustments to the bars because the frame stack and reach was 20mm longer and a spacer taller. The kicker, I’m only 6’ but rode steep and am mostly upper body.
Mind if I ask your inseam?
Edit: I have no freakin’ clue.
I’m 5’9.5 and the M-S fits me like a glove…if I had to, I would probably go to S before M-L…
What stem length do you use? My 90mm stem seems waaayyy too short
2016 tm02
6’1.5"
Size L
But i am definitely long torso.
I’m 6’1" and have a 2017 M-L. It seems to fit well.
Whoops. Totally thought this said tm01…my mistake!
2016 TM02
6’ 1"
M Long
Re the TM02 - why the huge price discrepancy between the 105 and Di2? In Australia the 105 is AUS$3700, but the Di2 version is $7000! Only difference is Di2 and wheels.
In the US, Di2 is more like $6k and those wheels are ~$1k alone. Other than that, not much difference.
Are the stack and reach numbers in the database still accurate?
S 480/393
M-S 515/377
M-L 515/418
L 556/442
6’2", large with a 110mm stem
5’4 and ride a 2013 M/S
