If you wake up to a flat tire on the F150 Ford van and if it was your 51 birthday the day before . Would you if you could get away with it . Blow off work and ride the day away. Is this a bad plan ? Are their any others willing to blow off work for such a small problem ? What is your blow off work threshold ? Am I the only weak one !
Dirtball
It’s a Biopace world out their .
Blow off work for a flat tire - naw, I don’t think so. But a nice spring morning, on your way out to the car, when the sun warms you and the air smells fresh, well sure. In fact I’m starting to think that tomorrow could be a good blow-off day. Little stuff gone bad doesn’t usually get to me - when life is good, then I’m willing to change it up and go ride the day away.
Absolutely! Blow it off!!!
As long as my numbers at work look ok, my blow-it-off threshold is pretty low. Work will always be there. As long as your able to meet your obligations and responsibilities, then why worry? Get out and ride. You’ll probably perform your job better the following day because of it. Work hard, play hard!
The old excuse: I have a problem with my eyes: I can’t see going to work!
Luckily my workplace is pretty flexible and I can take a day at a whim. Even two. But since it’s pouing buckets out, with lightning to boot… I think I’ll work today.
