RBC - 6.46 Ref Range 4.63-6.08
HGB - 21.4 Ref Range 13.7-17.5
HCT - 59.5 Ref Range 40.1-51.0
My un-athletic doctor thinks these readings are abnormal. I assume these numbers merely indicate a chronic dehydrated state. Should I drink a couple glasses of water and get re-tested?
I’d get re-checked. You might be blessed to be a genetic marvel, but more likely lab error. I doubt that there is anything actually wrong with you, but it is possible.
Yeah, I’m not gifted. Probably just need to drink something every once in a while.
I’m no expert but those to me are scary high numbers. Like others said, you’d likely be accused of doping. I’ve read an article about a journalist who wanted to see the effects of some of the doping products. He used EPO to increase his HCT and got it UP to around 50. 59 is crazy high (maybe even dangerously high) so far as I understand it.
Your non athletic doctor is correct and you should go have these checked. They may run the tests again, but if correct, then this definitely needs to be investigated further.
If the indices are still that high you are at risk for such badness as a stroke or obstruction of other important arterial supply. You need to be phlebotomized at a minimum. Further lab diagnostics can be done on the blood after you are bled down to a more human level.
