I always said with strong conviction that the Cervélo R3 was a much more comfortable ride than the aero Cervélo S3. I could not tell why but I always found the vibration on the road to be much harsher on the S3.
After discussing with many and a total lack of data about comfort and how to measure it…I decided to use the best option, a home made, not professional blind test of those bikes.
The first issue is…how do to a blind test, well, I didn’t think I could cover those frame in a proper way and it would be too much work on a brand new bike sitting at the store. Instead, we decided to build a helmet that would not allow me to see underneath me, so I could see forward…but no down. Impossible for me to know what bike I m riding!
Genius isn’t it?
The helmet:
The fit!!!
Both bike with same position, both bike with the same set of wheel…put on one bike…then on the other one
90psi
Same saddles
Different group(components) Because of this, I wasn’t allow to shift gear…I was wearing very big cloves and hoding the hood of the brake so could not feel much of the levers of difference in bars.
The mechanic would put the bike in a 53X17 and send me around a 1000m loop with 300m of rough pavement. I would repeat as long as we wish. I would not handle the bikes or changes…someone bring the bike to me, put me on the bike without me touching the bike. So…I had no clue what bike I was riding.
Results
1st run I was 80% sure to be on the S3…a little harsh ride. The true R3
2nd run I was convience I was on the R3…more comfy but difference was small The true S3
3rd run I was convience I was still on the same ride as run #2… The true S3
4th run I found that one to be the comfiest ride of all 4 runs…but I was in a state of comfusing as to what was what The true R3
So in the end, I was not able to identify the bike in the same way I would have predicted. I have realise that when blind…it become much harder to see a difference in comfort. Of course, there is a lot of mistake/issue with this test, but it show how wrong my perception was in the first place. Both bike are much closer than I realise and a lot more testing would be needed to see if a difference is reliably recognisable.
So…if you think one bike is much harsher than another one…perhaps try to blind test… it will be a eye opener… I was dead wrong in my hypotheses and learned something today…
