Originally published at: Bikes of Kona 2024: Matt Hanson’s QR V-PRi - Slowtwitch News
FRAME – Quintana Roo V-PRi
QR is known for its custom paint options, and this one is no different.
Cockpit – Drag2Zero .66 The non-UCI legal front end is Drag2Zero’s flagship setup. It’s clean, and unlike some others, we have seen it has no crazy 3rd part 3D custom parts that are duct taped together.
Matt will run a single rear Gorilla XT bottle and ISM PN 3.0 saddle.
Shimano is all around the drivetrain here. 56-44T for the front chainrings and 11-30 on the rear cassette. Matt also uses a crank-based power meter with 170cm arms.
DT Swiss ARC 1400 80mm front and rear. While he will ride the same depth wheel, he will ride different tires and sizes. There’s a Continental Aero 111 700 x 26c in the front, Continental GP500 Tour 700 x 28c in the rear.
Thanks to QR’s triathlon non-UCI roots, Matt will have plenty of storage for the long haul, although while discovering the tire plugs instead of a tube, I did ask Matt if gravel was in his future.
You can also find more information on Matt here on his IG
