A co-work, who is an avid mountain biker with several high end bikes, decided he wanted to test the road bike waters without jumping in too deep. After some discussion and research he bought a bike from Bikes Direct, my first experience with them. I figured if 2 mechanical engineers with 60 year of design and manufacturing experience between us couldn’t make it work we were a lost cause anyway.
The bike was listed as Motobacane Vent Noir with a 105 5900 drive train. $1350 on sale for $829. It was bought 5/5/15 and showed up on 6/3/15.
It showed up in a box with the front wheel removed, the handlebars and seat removed, and the front brake removed. The bike was blocked, taped, and tie wrapped everywhere. It was not cosmetically damaged in shipping. Not a scratch on it.
We assembled the bike and put it in the adjustment stand. The wheels are Weinmann, the cockpit is Ritchey, and the saddle is a no name (literally, no name on it anywhere). The frame has 6061 AL stamped on it. Welds looked sound and clean. 105 5900 shifters, FD, and RD. Tektro brakes, FSA crank (that I have never seen before) and SPD compatible pedals made by Wellgo (RC-713), another “never heard of them” brand. There is a generic assembly sheet in the box that told you pretty much nothing. It was so generic they should have just not included it to start with.
Adjustment
The brakes were taped in a manner that was not readily noticeable, and it stopped them from working. Once the black tape was removed, the pads were adjusted for position, and the cable tension set correctly (front was too tight, back was too loose) they seemed to function fine. Out of the box, even with the tape removed, they were borderline dangerous. One pad was rubbing the tire, the other was rubbing the fairing on the wheel.
The FD was also taped in a manner that made no sense (it didn’t secure anything) and it stopped the FD from working. Once removed it still didn’t work. I ended up releasing the cable and stating over, including adjusting the pitch angle and height, both of which were way off. Once a full set up was done it worked perfectly.
The RD was working but making a lot of noise, and it would not shift to the 27. I adjusted the high and low limits and it got better, but eventually I just release the cable and started over. After doing a full alignment and adjustment the RD was quite and shifting correctly.
Conclusion. You get what you pay for, and Bikes Direct seems to be upfront about things. I would guess that the average garage mechanic would have had a tough time adjusting this bike so that it worked properly. It hasn’t been on the road yet, but it looks to me like it was well worth the 4 week shipping wait, 2 hours of assembly and adjustment time, and $829. Just be aware that it requires some skill to assemble and setup, so if you don’t have the skills and tools you need to add that cost (about $120 at the LBS I would guess). It isn’t an IKEA table and chairs, that is for sure.
