Bike trainer, echange front and rear wheel
I have a old bike that I do most of my indoor training on, and it seems the rear wheel is a bit mis shaped. Can I just exchange the front and rear wheels, instead of buying a whole new set?
no
Either I’m confused or this is a very strange question.
google how to true a bicycle wheel and fix your rear wheel. All you need is a spoke wrench to get close enough.
You mean tire and not wheel correct? if so yeah you can change them, but you should use good tires for riding outdoors.
  • You mean tire and not wheel correct?*
Ah, that would make more sense. Although if his tire is misshaped, it might be an installation error.
if the wheel is just wobbling left and right a bike shop can true it for you cheaply
Don’t swap the wheels. Instead just turn the whole bike around and put the front end in the trainer.
This works, you may have to pedal harder though.
I’m a bit confused. A wheel or the tire of your (http://www.cycling-secrets.com)? Well, it would be better if you should find ways to change the damage part than to replace the entire trainer. It would be costly.
