Hey, complete newbie here. Just wondering what you guys generally wear to do a bike/run brick. Do you run in bike shorts, bike in running shorts, wear a tri suit, or get changed in between? I’m training for a sprint, so I will be wearing a tri suit on race day.
Welcome to the sport! I’ve done all of the above. Just have whatever you want to wear on the run ready where you finish your bike. An extra minute to change in training won’t affect anything since you are not being timed. However, I would make sure that you simulate race day at least few times so that you can get your transitions down. Wear your tri suit for the bike and practice chanigng your shoes grabbing what you need and getting gone. Good luck and welcome to the addiction!
If I’m planning to run after my bike workout, I’ll bike in trishorts then throw on a t-shirt to run. The ladies I pass don’t seem to mind the tight shorts.
I wear my tri suit, but my longest distance is 70.3.
I would go with your race wear at least a few times before the race.
If you’re doing 140.7 and plan on changing to running shorts after the bike, then train that way.
Cheers!
Depends on the bike plan. I run in whatever I bike in. I never do long runs in a brick—max 15-30 minute runs. So, I don’t really care what I’m running in. Note that I don’t do races longer than OLY.
My tri-suit isn’t super comfortable—so, I usually don’t wear it for rides longer than about 90 minutes. Thus for long bike/brick workouts I wear bike shorts. When I start doing race-sims, I will wear the tri-suit.
I ride indoors. Usually just have a pair of running shorts and shirt next to the bike. Nice to get out of the sweaty clothes even if it only lasts 2 minutes.
I always wear a tri suit when biking or cycling clothes and then a few times I run in the tri suit and carry my nutrition so I can get used to having it all…I would suggest running in your trisuit once or twice before you race so you know what its like to bike and then run in it…and welcome
I wear what is comfortable for the bike. For longer rides I wear bib shorts on the trainer. Most of my brick runs are 15 - 20 minutes. So, I will just throw on a shirt and run in the bibs. I wouldn’t do a marathon in them, but no harm for a short run off the bike.
There are times when I will change into some shorts, but this is not typical. Maybe only if I am wearing bibs with a thicker pad. Or if it’s a high traffic volume type of time of day. Don’t want to embarrass my kids
I run without socks. I would say training without them is propbably more important than what I am wearing for shorts.
For a longer brick session, I’ll usually use my Tri suit, but sometimes I do short ‘transition runs’ following a bike ride. Since that is usually in my neighborhood and I’m likely to be seen / recognized, I keep a pair of looser shorts with my shoes in the garage. ( With my middel-aged body, I avoid tight clothes in public - YMMV ) I get in , rack the bike and throw my shorts on and go run a mile or two. Bike shorts with a larger chamois aren’t ideal for running, but for a mile or two it’s no big deal.
