there is now a “comments” section that attends each bike you input, so that you can add whatever information relevant to you: saddle, aerobars, gruppo, wheels, as well as the bike’s make, model and vintage if it’s not listed in the drop down menus.
post here if you think other brands or models ought to be on this list. keep in mind:
our intent is to list the bikes that 95% of you are riding. the other 5% aren’t going to get listed in the drop down menus.
we’re only interested in databasing tri bikes. we want you to be able to list your road bike coordinates, but we’re not going to pair these coordinates to specific brands and models and manipulate the numbers, as we will with tri bikes.
Can your guys add a check box for custom/non-custom (or stock or off-the-peg or whatever they want to call it). Non-custom could probably be default, too. Might be some interesting results from that bit of data…at least some data leading to some questions which might beget some interesting answers.
I have input the date in MM and continue to get a message to make sure I use MM…for some reason I cannot save the data after input…what am I doing wrong?
there are ranges that i set that seem reasonable to me. if your input for a given metric falls outside that range, it won’t take it. i set this range because people often use cm instead of mm. why don’t you double check you’re not doing that, and if you’re sure you’re not, post your inputs here so i can see them.
