Bike Drink Recommendations
Alright I have been using the same stuff, GU Roctane on the bike for quite a few years and looking to try something new as I need a change. More just tired of the same old stuff at this point.
Here is my list of what I like and hoping to buy a couple samples to try a few new options,
  1. I need something with quite a bit of sodium as I sweat a ton.
  2. The more calories the better as I prefer to drink more calories than eat solids.
  3. I like some flavor (tried Tailwind but just to bland for me)
Just what is some of your favorites out there to try?
I switched this year from Tailwind to Skratch. I found the TW bland and well and personally like the flavors better which means I drink more. I just use the regular hydration mix which is 80 calories per serving but they do have a supefuel version with more calories.
Infinit custom blend. Get exactly what you need and want.
I love Skratch, I use mostly on easy days or shorter rides as I don’t think it has enough calories for me. Saw their new super fuel just cost so damn much.
The problem I have with Infinite is I am not willing to spend what they charge to try some custom blend that I may or may not like. If they had a custom sampler pack of a couple custom blends you could make maybe I would be open to it but probably doesn’t scale for them to entertain that model.
I like the homebrew option. I use dextrose, electrolyte tabs and flavor drops like Mio or Koolaid to get the flavor I want on the day. I find Lemon SiS to be a good base for the electrolyte and easy to change the flavor.
+1 on homebrew
I’m partial to maltodextrin as the carbs (doesn’t add flavor…just a slight “creaminess”…readily available at the local brewing supplies store ). Once you have a mix that works for you, you can change the flavor whenever you want by just getting a different flavor of MIO (or any other zero-calorie flavor drops).
I like table sugar with iodized salt, a bit of squeezed lemon or lime for flavor or maybe even a bit of fruit juice
Perfect. Easy and economical. You can ride hard all day on that formula.
I realize that Maurten is expensive but… Oh man, I am a big time sweater too, and then crampy like no other…
I got the sample pack and used it this summer on many rides over 140 miles. Nary a cramp nor severely dehydrated. I love the stuff. And now they have a caffeinated mix, BRO, this stuff is great.
I also use Skratch.
daved
Thanks, new one to me I will check it out.
Well, I obviously can’t speak to your finances, but a $20 investment to potentially address all of the concerns you outlined seems like a fairly low risk proposition.
Have you tried the Tailwind cola flavor? That’s my new go-to.
I wasn’t aware of anything they did for $20 I thought almost all their options were north of $60. I will go back out and take a look at their site.
I wasn’t aware of anything they did for $20 I thought almost all their options were north of $60. I will go back out and take a look at their site. it’s only 5 servings so, admittedly quite pricey per serving. But would give you the chance to try with less invested. And, I found their consultants are quite helpful too.
OK thanks. I will check it out as I must have missed that option in the past.
I use UCAN and love it. I buy an unflavored canister and also flavored , then I mix it depending on the ride. I make concentrated bottles and then just use water in my aero bottle. I love it for many reasons…no sugar, mixed well, no stomach upset, can be different concentrations depending on what I need. Also, it’s not sticky, so for windy, hot races, it’s awesome! Good luck with your search:)
If you want to try something different, that is probably going to be fairly cost-effective, I’d suggest F2C Glycodurance. The stuff is made here in the Fraser Valley of BC, Canada, (where your Yankee bucks are worth about 30% > than our Canadian dollar).
It has a very gut-friendly sugar base, blended with electrolyte. I did the new Ironman Canada bike course using ONLY that, once in hot (90 degree) weather, once in mild (72 degree weather). Things worked out very well for me. A solid energy base, decent taste, no drama in the guts.
This was a significant game changer for me, I no longer need to carry any gels on either the bike or the run. Well worth the cost, when you consider how much we spend on bikes,accessories and clothing it really isn’t that bad of a deal, especially when it is made just for you not by some random model
I recently wanted to try some new nutrition stuff so i ordered a bunch of single serving options from thefeed.com. They have a bigger selection than any of my LBS or run stores, and i liked that i could order small amounts of many things. SIS has a drink mix (Beta Fuel) with lots of calories that you may want to check out. You can also get Maurten from them (i’ve never tried that).
When i placed my order i got a free water bottle. I’ve only used thefeed once, but was impressed with the selection. I just wish the pricing was better.
