I’m looking for a bike computer that supports ANT+ that isn’t GPS. I want the battery life of an old school wireless bike comp, without having to put additional sensors on my bike. I record my rides with my Garmin watch, so I’m not interested in a GPS bike comp, or the limited battery life they have.
Giant made/makes the NEOS ANT+ computer, but it’s unclear if it is discontinued or not. Since it’s only in the store, and no longer on their products page, I’m assuming it’s discontinued. If they had any of the black ones in stock, I’d buy it right now for the $35 price. Does anyone have any experience with that computer? Giant lists the battery life at around 10 months.
Ideally there would be a bike computer that just showed the data from my watch, like the Wahoo RFLKT, except getting data from the watch instead of a phone.
It is not clear to me that the NEOS logs data. I suspect it doesn’t. So if you wanted to store data then upload it for analysis or logging, it might not be for you.
Your Garmin watch doesn’t have ANT+?
Don’t need data logging, I’m doing all of that with the Garmin watch. Just want to see my cadence, speed, distance, and time on the bike computer. And I don’t want to have to charge it every few rides.
That’s a good option, albeit a touch expensive (But all of the options are more than I wish they were). At least it looks to be a current product. Wish they listed an average battery life for it.
I’m quite sure they had a previous version. Couple of years ago I looked at the same thing, and I’m positive Bontrager already had one. Maybe it can be found on sale by now. (Never bought such device though).
I have an old Cycleops (Powertap) Joule computer (not the super old one) sitting around somewhere that does Ant+ but not GPS. Not sure on the battery life of it now but it was good when I stopped using it.
Edited to add: Just looked it up, it is the Joule 2.0
What you are talking about is called Extended Display by Garmin (data from the watch to the display). The Edge 130 is probably the cheapest compatible with this, and the 520 Plus also. You may be able to find these cheaper 2nd hand.
Just runnning the display (and backlight, depending on time of day) means pretty long run times.
What you are talking about is called Extended Display by Garmin (data from the watch to the display). **The Edge 130 is probably the cheapest compatible with this, and the 520 Plus also. You may be able to find these cheaper 2nd hand. **
Yeah, but if I’m using those, I might as well use the GPS on them and charge them after the ride.
I ended up getting the Giant Neos Ant+, even though it seems to be discontinued, and it works great. Picks up my Speed and Cadence sensors, and also the HR from my watch. I bought it because it was the cheapest at $50. But the mount for it didn’t really work on my bike (Felt S32 (2006)), so I ended up buying a Garmin Quarter-turn mount and an adhesive quarter-turn adapter for the Neos ($20 more). Looks decent, we’ll see how long it lasts.
I’m still waiting to see on the battery life, but it still shows full battery after 5 hours of use, so I’m hopeful.
Can you turn off the GPS function on your current unit and just use the data you want/need to view.
My original unit was a wired bike computer (2006) that died this spring. My new unit is just an ANT+ capable bike computer, no GPS, so it calculates speed from wheel rotation and circumference. I record my rides on my Garmin 735xt.
I was trying to avoid using a GPS computer (I have a cheap Bryton), because I always forget to charge it. I’ve never tried turning off the GPS on that to extend the battery. I’m not even sure you can turn GPS off on the Bryton. If I do eventually get a GPS bike computer, I would likely get a higher end one that supported maps. That would be especially nice if I was doing more MTB trail riding, but right now I don’t see the need.
You can turn off GPS easily on Garmin devices. Old Edge 500s are selling super cheap and I haven’t tested it other Garmin device use 3-4 times as much juice when GPS is on so I would expect 50-60 hours of run time on a 500 based on the stated GPS run time of 18 hours. If you turn the backlight off I bet it would go even further.
