Hi,
I hope I can get some valued expert opinions to help me chose the best possible wheelset for IM 70.3 Wiesbaden / Germany.
Some background Information:
IM 70.3 Wiesbaden is a hilly course with 1.430 meters total ascent. The longest continuous climb is 5.2km at 6.3% grade, the steepest section of which are 2.8km at 8.1% grade.
My weight is ~78kg. My current FTP is 274 Watt, I aim to increase that to >285 Watt which would give me >230 Watts at IF 0.81 on raceday. My bike is a Scott Plasma 3.
I have to pick between two wheelsets:
- HED Stinger 6 front with Continental Sprinter Gatorskin tire, butyl inner tube. HED Stinger 60 rear with Continental Sprinter tire, butyl inner tube. Wheelset weight around 1560 grams without tires.
- HED Jet Plus 9 front with Continental Attack tire, latex inner tube. HED Jet Plus Disc rear with Continental GP 4000 S II tire, Latex inner tube. Wheelset weight around 2040 grams without tires.
Obviously, the Jet’s are a lot heavier. On the other hand, I assume that the tires have a lot less rolling resistance, in addition the Jet’s should be aerodynamically superior (which won’t help me uphill but on the descents, I guess).
So which one would you pick?
Many thanks in advance and best regards,
Frank
