What is the best wetsuit for a maximum flotation of the legs? Quintana Roo with the virtual pullboy? I use the pullboy with all my training sessions.
Testrider. There are many suits out there, and the Virtual Pull buoy from QR is is a great working concept (the designer of that needs an award) but! You need to look at the rest of the suit and the balance of the buoyancy and how it interacts. The best option is to have more buoyancy in the thighs, hips , butt and lower leg and a little less in the torso and chest. This way you have a definite change in your axis and a more streamlined and leg high position.
I suggest you try what Rasmus Henning did and that is the new blueseventy AXIS. 5mm aerodome legs etc and 4mm chest. But of course there are other wetsuits out there.
Cheers
Deano
P.s. Hats off to Emilio for trying to innovate and having that crushed by WTC and USAT, keep thinking buddy, there will be something else in your head I am sure.
DeSoto Water Rover
Water rover is not allowed in Europe. Even Ironman races in europe use the 5mm thickness.
How do they test in Euro? Or do they just go by reviewing “advertised” or so called manufacturer published specs?
With all the recent communication about the Desoto WR was curious. I guess restated if someone showed up with a WR without any labels would they get caught?
I am not proposing people do this, nor would I, just curious.
Thanks,
RF
They can not test 2500 people. The Water Rover is not such a buzz in Europe. In fact, someone in my club uses a Water Rover (He gains 20 sec in the pool with the water rover for 400 metres, previously he had the Zenith Zoot). He will use it regardless of the rules. Normally that will pass, but I find you should follow the rules.He is now faster then me :-(. Because if you do not follow the rules, you could also take some short cuts on the run/cycling course etc…
