Best Wet Suit for Stocky Build
I am in the market for a new wet suit and wanted to get some recommendations. I am a 5’7" male and weigh 170. I have an endomorph body type (short and somewhat stocky) and am looking for a wet suit that will best fit my body type. Thanks.
I am just a little bigger than you at 185 but am 5’7 as well. I have good experience with 2xu sized MS which stands for medium solid and aquaman wetsuits I am good with a large. They both allow my shoulders to have full movement as long as I get the sleeves ALL the way on. Or else it feels like you’re pulling a rubber band with each arm when you swim. Really annoying
I went and tested several brands and the best one I found was the HUUB Aegis in Stocky/Strong size. I’m 5’8" at 175lbs and it fit perfect - Specifically at the neck. It doesnt ride up too high on the neck like the 2xu did. Got it on Amazon for $125. I’m at 165lbs now and fits just as good.
Look at DeSoto two piece, you can mix up the top and bottom for a good fit. If you buy from DeSoto, try it if you don’t like it send it back.
https://www.desotosport.com/products/wetsuits/index.php
I have a similar build, and both the Desoto T1 (4 top and bottom) and B70 Helix (M) have worked well for me.
Lose weight.
