Best tubular for front Zipp 1080. Is it a 21 mm Vittoria EVO Corsa CX II instead of a 23 mm?
Can someone recall what Josh mentioned in a post I can’t find?
Sergio
Zipp site sight say’s a 1080 is better paired with a tangiente. I wonder why though
Basically the same tire, and more marketing for Zipp… no shock there.
I run the 21 (Evo CX 2) with the 404, not sure if the 1080 is different
I run a 21 Evo CX 2 on a C2 HED Stinger. Seems to fit well but is there any concern about the trend towards thinner tires and wider rims? In terms of a tire rolling off.
I had no issues on my Stinger 9 with a 21mm , I had at least one descent at 45mph and had no shudder, or scare of rolling. Just my .02 (Does look goofy on a HED though :slight_smile:
I found the information I was looking for in the Zipp site:
Tire choice depends highly on user preference and conditions. To summarize, a 21mm has superior aerodynamics with our rims; a 23mm is larger and subsequently has better ride quality and rim protection, but at a slight aero penalty. Here are some questions you can ask that will help guide your decision: * ** * * Triathlon/Time trial? In general – 21mm.* Road racing? In general – 23mm. *Training and/or daily riding? 23mm+ * Dry? 21mm at normal recommended pressure. *Wet? 23mm at a slightly lower pressure. * Smooth roads? 21mm at normal recommended pressure. *Rough roads? 23mm at a slightly lower pressure. * User prefers slight aero benefit of 21’s at the expense of a little ride comfort, rim protection, and rolling resistance? Use 21mm. *User prefers slightly better ride comfort, rim protection, and rolling resistance of 23’s at the expense of a little aero? Use 23mm. * Rider weighs less? 21mm. *Rider weighs more? 23mm. *
Thanks,
Sergio
had the same question on tires for the HED Stingers this week as I am replacing tires so I called HED and they recommended going with 23’s for the Stinger 9 & 6.
Official answer from Zipp - 21mm.
Yes, HEDs are optimized for 23mm. The Stinger 9 is marginally faster than the 808 with a 23mm on both, the 808 is marginally faster than the 9 with a 21mm on both. So the universal answer is 21 for Zipp // 23 for HED. It is - however - a VERY small difference in each case.
Ok. It is clear now.
But I now have another doubt. You mention that the S9 in some conditions is marginally faster than the 808 but, is that wheel also faster than the 1080 in some conditions?
Sergio
Sergio
I am sure it would depend on who you ask, but the answer from Zipp - and the same answer that you’ll get from me - is absolutely not. The 1080 is significantly faster in all conditions than a 808. The 1080 is also more “forgiving” of tire width than the 808 - it slows down less with a 23mm tire on it.
I was looking at the HED site today for warranty information on the Stinger 9. Never noticed it before but HED indicates that warranty on the Stinger 9 will be voided if you use anything thinner than a 23mm tire.
Not sure how they would know but thought this was interesting.
Also, I am pretty sure that HED indicated somewhere that the aero numbers on their site for the Stinger 9 were with a 21mm Vitoria CX II.
Having looked at the way a 21 mm seats on the S9 I think it is reasonable for HED to indicate that the warranty would be voided if using a 21 mm. Doing the WT testing on the H S wheels with a 21 mm does not sound reasonable. Where did you see those results?
Sergio
