Any recommendations for some tire levers that can be used to remove extremely tight tubeless tires on carbon rims .
Which tires are you trying to mount?
Vittoria Rubino 30mm T LR G onto Reserve 35mm Rims
I find the ability of Schwalbe tyre levers to clip on to the rim makes fitting TL tyres a cinch.
I just use my old Pedro’s, although GP5000TLs aren’t a particularly tight fit on HED V6s.
I’m in love with this one. I’ll never use another lever.
https://www.amazon.com/gp/product/B008UY1MXW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
These are nice: http://www.tubelesssolutions.com/store/p1/Beadbiterkit.html#/
Similar to the Schwalbe ones that somebody else posted, you can hook them on your rim to hold the tire in place as you add sealant, use them as a third hand as you try to get the tire back on the rim, or just use them as a fairly strong lever. TBH, I try not to use levers ever, but with some wheel/tire combos I need them, and these Tubeless Solutions ones do the trick.
I also have a crank brothers one like posted above. Feels very sturdy, but for some reason i never end up grabbing it and use the ones i posted above instead.
https://www.amazon.com/...le?ie=UTF8&psc=1
x2. Buy it now and thank Dr. Alex later.
Not much use for removal which is what you specifically asked about (never had a problem with any levers for removal) but for installation (at home), the KoolStop Tire Bead Jack is amazing. I’ve had two disappear on me when my friends have “borrowed” it. You could carry it around in your jersey pocket I suppose (I wouldn’t want to), but installing new tires at home couldn’t be any easier with this thing regardless of the rim/tire tolerances.
