I am interested in hearing what others think the best gear out there is - be it swim, bike or run. I have my own opinions, but want to hear what others think.
I’ll start off:
Thomson Masterpiece Seatpost. I have an Elite, far and away the best component I own. Easy to adjust, durable beyond belief, and now that they cut some of the weight off with the Masterpiece, it is one of the lightest 330mm posts out there. This will be standard issue on every bike I own in the future.
Aquasphere Kaimen Goggles: Not sure how I survived without these. They never never leak and are very comfortable. Just don’t leave them on the front seat of your car in the summer heat…
Amphipod Runlite Snapflask: The holster can hook on to just about any belt and can be placed anywhere on the belt. The bottles have a large mouth and a great seal - never leak. They snap in either vertically or horizontally. Far ahead of Fuel Belt.
Aerus Composites seatpost. Extremely adjustable, bladed seat post. Very comfortable, and allows a wide range of fore/aft positioning to get you as far forward or far back as you like.
DeSoto 4-pocket Power Tri Shorts - the most comfortable piece of clothing I own. I do all my cycling and bricks in these shorts. Add in the 4 pockets and a Fuel Belt, and you can carry all the nutrition you need for those long runs/bricks.
Silicone swim cap. I bought it as a newbie because I read that they last longer, and thought I needed one for pool swimming. Well, it wasn’t too long before I realized that I didn’t need to buy one, as I now have a multi-coloured stack of ones from races. However, this year as I was doing more open water swimming I brought it out… holy cow, that is the most comfortable swim cap ever. I hate the latex ones they give out at races, but this one is some incredably comfortable. Highly recommend it.
All the rest of my gear is pretty average, so nothing else really to rave about.
Would you guys elaborate on what it is that makes the Tompson Masterpiece such a must have? I’m building a bike from scratch right now, I have handpicked every component for it and the seatpost is the only thing I haven’t bought yet. I’ve owned a lot of bikes in my life and rarely gave my seatpost much thought and I’ve luckily never had one break. Why do I want to pay as much or more for the Tompson as I would a carbon or Ti post?
Well, first off you need to understand that a carbon seat post does not - in any way - make a bike more comfortable to ride. Same for Ti. A post is a post is a post.
What makes the thomson so nice? First of is the build. It is one piece, top to bottom, there are no welds, no epoxies, nothing but machined aluminum.
It is also extremely light. Weighs less than most carbon posts.
It is stronger than any carbon post because of how it is built and what it is made from.
Carbon posts slip. The Thomson has little ribs going down the length of it, it will not slip - at least mine never has.
The seat clamp can handle some insane amounts of torque - your seat will fail before it will.
It is a microadjust post - if you want the nose just .5mm lower, the Thomson can handle this for you.
If you are not a weight weenie, get the Elite. It’s heavier, but just as strong.
If you can see one at your LBS before you buy, you’ll know immediatly. Beautifully machined, clamp is not a seperate piece, all one. Graduated degree markings on clamp w/ no worries about ever rattling loose. I had to buy one of these beacause my Look takes 25.0mm and that is a weird size combined with my need for an extra long post, limited my options. Had an American Classic, it was relatively a POS compared to this beauty.
Basically, it comes down to craftsmanship. Thomson posts are the Rolexes (or whatever other fine watch you prefer) of the seatpost world. The tolerances, design, and finish are all excellent.
It is very light – comparable in weight to any other material.
Vs. carbon – you don’t have to be as concerned about pinching the post at the binder. There is also not the concern about the clamp/post joint with a solid post like the Thomson.
Vs. ti – only concern is finding something that is of the same quality. Ti is an excellent material, but if the workmanship is not as good, why bother? The Masterpiece is machined to perfection, not extruded. The beautiful oval inner wall is something you just won’t see on any other seatpost.
They also have a “bending fuse.” Seatpost will not snap off, but will fail in bending, meaning you will be much safer in the event of a catastrophe. It is a little thing, but offers peace of mind. The failure loads for the Thomson post are also ridiculously high. So the likelihood that you will ever need the safeguards they put in place is minimal. But they still put them there for you.
I second the Thomson Masterpiece and Elite posts. I’ll use nothing less on my bikes (well, except my cyclocross/commuter… it’s just a cheapie).
Here are some other nominees:
Chris King headset. The gold standard. The only thing that hurts them is the price. You can get a very nice FSA Orbit X headset for less than half the price and it will work fine.
Campy Chorus/Shimano Ultegra. For the price, they can’t be beat. Good enough to win pro races, but cheap enough to be affordable for lots of people. Yes, every group has its shortcomings, but these two win in my book.
Body Glide. It works.
Puma H-streets. Quickly becoming my favorite shoes.
Jandd transition bag. Lots of room and compartments. Comfortable to wear. Works well.
Reynolds forks. They’re strong, light, and like the other nominees- they just work. The only thing taking away from them in my mind is the carbon steerer. I’m slowly beginning to accept the whole compression plug deal, but I do prefer an aluminum steerer and star nut (like my Bontrager XXX Lite fork- 370 grams with an Al steerer!).
Giro Atmos helmet. Light, well vented, and comfortable. Very sharp looking, too.
Sidi shoes. I have yet to find anything better (and I own 4 pairs to prove it).
