Best downtube aero bottle
for trek speed concept if that matters.
Is a aero cage really worth it?
I really like the torhans vr bottle. Although I use it on the seat tube but I know many a riders who use it on the downtube.
Small gains but free speed. Use one if you only need the one bottle on the frame for the race. I like Torhans VR as I have ejected aero bottles before on a rough course but it is supported well and definitely won’t eject.
Elite Chrono on the down tube. You’ll have to use the cage it’s designed to work with.
Highjack:
Before I buy a a goofy aero bottle, order of preference for the speed concept is (1) BTA, (2) single bottle BTS, (3) aero bottle on downtube, right?
None, next.
I’m currently using the X-Lab aero bottle for racing, and I use it on the seattube. It seems to fit a bit lower on my frame (Blue Triad SL) than on the downtube.
I’d prefer no bottle in that position, but I feel personally it’s better for my nutrition. I use one concentrated bottle of Infinit in a HIM and two for an IM. I’ve thought of putting the Infinit behind my seat, where I do have a cage, but taking a drink every 15-20 min is hard getting the bottle out of and back into the Gorilla cage. I generally start a race with a water BTA, one behind the seat as well as the X-Lab aero bottle.
For a real hilly course I would forgo the rear bottle at the start to save a bit of weight. The only advantage of starting with two water bottles is generally only having to slow down at one aid station in a HIM to get more water.
This.
It’s very, very hard to go wrong with a BTA and often a BTS is pretty neutral
The SC is one of the few bikes we’ve made go faster with downtube/seattube bottles. But you need the right size SC otherwise there is a drag increase. On the other hand not having that nutrition, getting off the bike staggering through the run (or run/walk) on fumes is probably the slower option
I use an XLAB Aero TT on the down tube of my Trek SC. Not sure if it’s faster or slower than the Elite Crono, but it holds 25% more (at 20g heavier) if that matters.
I found one of your old posts re: the subject and IIRC, small/medium there was no penalty for a round bottle, but with a large there was. Do you remember what gen those test were ran on? I’m on a medium 2012 (the older gen frame).
probably 1st gen since it was 4-6yr ago I’d guess
Yep, I was told by Jan that didn’t change his drag on the Canyon at all.
As best as I can tell from field testing, it’s drag neutral for me as well.
I have a SC - XL Gen2 that I like to run an Elite Crono2 on the downtube. Thoughts? No bottle seemed always best, but I have to run mine on the downtube as I drop it too often on the seattube.
Thanks everyone. Have a BTA horizontal-oriented Profile Design but wish it had an easy refill foam http://www.profile-design.com/product/hydration/aqualite/ cap like the old vertical Profile Design Aqualite BTA. Which makes me wonder-which of the suggested downtube aerobottles would be easiest/fastest to refill the flip open solid cap top of BTA I have now (horizontal) ?
I have been running the Specialized Virtue aero bottle on my Gen 2 SC. It fills the gap nicely between the downtime and seat tube. Don’t know if it is any faster than or slower than anything else.
I say Tim Reed running one and figured hey I have one why not? (I know, great reason right)
I would lean toward the X lab just because you can see how much fluid you still have compared to the Virtue or Chronos, just my worthless .02cents
I have been fond of the xlabs Torpedo BTA on my SC with the no longer sold Bontrager RXL BTS mount that holds 1 or 2 bottles. So I do not use a frame mount.
None, next.
This. You spend thousands on a totally aero tri bike carbon frame, and you’re gonna put a bottle on the downtube?. That’s just wrong. Hydration should go in the cockpit or behind the saddle on a tri bike.
And the Giant Trinity? Comes with a downtube bottle…
Nothing is ever so easy to reply to with a few word, and certainly not downtube bottle aerodynamics
