Best BTA Water Bottle Cage?
Currently using a Bontrager Race Lite cage zip tied BTA. Had some launching issues so thinking of trying a better one. Any recommendations for a good one that is cheap (not looking for a $50 carbon one) that doesn’t launch but is still easy enough to get bottles in and out of while in aero?
thanks all!
Well, it isn’t cheap but after much searching I settled on Gorilla Cage.
It is pretty unstoppable.
speedfil z4, it has a built in garmin twist mount, and extra zip tie mounting holes
agree on teh z4
^^This.
^^ That
It’s really the best priced option you’re going to get for around the price range you want. If you want to throw down the coin though, and I haven’t tried it out, but I am kind of in love with the new Zipp Vuka BTA and it’s “bolted-in” option. The Z4, no matter how tight the twist ties will still feel not feel 100% solid when you remove/install bottles. I like options that are solid and immovable like the Zipp.
I’ve read great things about the Nathan system if you want to drop $75.
I bought an $8 profile design cage and zip tied it. I then bought a camelback big bite and put homebrew hose into an old bottle. $12 total. Looks bootleg but it works.
I use a Speedfill a2 with zip ties - no bottle cage at all.
XLab Torpedo cage or Gorilla cage. Sometimes zip tied, currently mounted on a carbon Torpedo Mount.
competative cyclist has the zipp carbon cages normally $60 on sale for $25. they are very good cages.
Here’s my current setup… XLab Torpedo in a carbon Torpedo cage (I bought the upgrade, not the 100/400) mounted on a carbon Torpedo mount. I have it Ziptied right now instead of the Velcro straps. I also removed the dolphin tale and use super strong magnets on the straw and the body to hold it down.
The Edge 810 is not mounted to the Torpedo mount, but rather on a homemade mount.
http://www.phone2forum.com/interface/scripts/viewimage.php?photoid=121713&code=jAIdVdto9bx7yOutgl5gIg%3D%3D
Specialized Ribcage.
Like the cage, not a fan of having my Garmin up on top though. I was using the Profile Designs Aero HC with my 810 strapped on top. Not exactly worth the BTA if you’re going to put a huge brick on top of it.
Zipp Bta mount puts the garmin out front, it is awesome. And it was designed with input from rappstar, which is also good.
We tested numerous water bottle cages during the development of our BTA mount and cage. It is surprising how quickly cages that you think are strong eject bottles readily in the horizontal position. There are only three cages I would say are “ejection proof”: the Zipp BTA carbon cage, SBC Rib Cage and X-Lab Gorilla cage.
x-lab gorilla is good, better than most. Your bottle ain’t going any where. The only downside is that it takes a bit of effort to get in and out, which is why it works in the first place.
…But this bottle cage (the Tortec Air Cage), I like better!
http://www.ribblecycles.co.uk/sp/road-track-bike/bottles-bottle-cages-tortec-air-cage/tortbotc260
It’s made of fairly flexible plastic with rubberized grips around the cage that keeps the bottle from sliding / launching forward. It’s flexible enough that it’s a breeze to pull bottles out / push them back in at any angle.
For the price, I think you’ll be very happy. I have the tortec and the gorilla cage, …and I prefer the tortec.
If you mount it backwards (opening facing you), any cage works.
This. I’ve never launched a bottle from a ribcage and they are less than $20.
Rib cage or xlab gorilla. Awesome!!
I have a couple carbon Ribcages, ejected a bottle on a Carbon Wing behind the saddle mount. I use them on the frame mounts and like them alot, just not on the back.
