Snapped a bolt head right off the Zipp aerobar clamp (that clamps to the Vuka base bar) this morning using my relatively new BBB Torquefix torque wrench. Got it from Trisports for $80. I wasn’t impressed from the beginning with the dial/setting handle. Pretty cheap look and feel. I like that it is very small and fits into tight spaces. Zipp stamps 5-7 Nm on the bar extensions - I set the wrench for 6 Nm (this one bar has been slipping on me) - BAM! snapped the head right off. Fortunately, I was able to extract the male portion left stuck in the bar and Home Depot had some replacement 4mm screws so my ride that I was heading out on in 45 mins wasn’t delayed.
Before someone asks - yes, I’ve used other torque wrenches before. This was not a “user error”. The BBB Torquefix has been used on several other parts on my bike. Worked fine but I questioned the accuracy because it “felt” like I was going pretty tight. Could it have been the quality of the bolt? Sure. But like I said, the BBB Torquefix is pretty cheap looking so I question the accuracy of it. I’m going to return it an get a Pedro’s Torque Wrench - a little more but looks like a quality item.
Don’t trust clicker torque wrenches. They are fundamentally flawed. They can work if they’re very well-made and have a strict usage and calibration procedure. But at that point they are far more expensive than dial or digital torque wrenches.
I purchased the Giustaforsa torque wrench (2 to 16 Nm) that was recommended by Leonard Zinn ($175 includes shipping from the US distributor) and after using it, I fully concur with the reviews given for this piece of equipment.
I don’t believe that to be true. I just had the calibration on my 8 year old Craftsman wrench checked and it was actually still in spec going into the cal lab. It was a $75 torque wrench. Cost me $25 to have it checked/calibrated.
They work fine as long as you follow the 3 rules of torque wrenches:
I’ve owned the BBB Torquefix torque wrench for a few months now. I like it. I was critical a while back of its design and thought it was the reason I snapped a bolt off my base bar. In reality, I think that bolt bottomed out. The ergonomics of the wrench are nice, the adapter is fixed to the bits and the price is reasonable.
I would recommend this torque wrench for everyday use in the home shop. I bought mine at Trisports.com.
I just bought one the other day and went around torqueing everything in sight. I have to say, all these years I thought I was over tightening stems, I was barely touching them if that thing is accurate 8nm on stem bolts is a heck of alot tighter than I had imagined. I guess it is always better to error on the light side for that sort of thing.
I have to say about the BBB I wish the handle had a ‘lockout’ as i find that I sometimes twist the handle as I’m torquing and change the setting.
I have used it many times…but alas…I just feel I get the same results with my far less costly, and far easier and cheaper to get Craftsman. Oddly, both at Barnetts and United cycling institues…they had Craftsman as well.
I had exactly the same thing happen this evening as happened to the OP. Adjusting a Zipp Vuka bar using a BBB torque wrench set to 6nm. I was alternating between the bolts to bring it snug evenly when on of the bolts snapped. It went from essentially no resistance to snapping. Luckily, I too had the bolt break at a point near the head so I was able to turn the remainder out with a pair of pliers. Pretty sure this wasn’t an issue of tool failure.
The only reason I can imagine to the the Giustaforsa is its size. If you want to carry a torque wrench around with you, this is the one to do it with. Buy it on Ebay for like 50% off.
Otherwise, your best choice is Park Tool. This is an extremely accurate toque wrench that is well constructed and will last for a long time if not your entire life. I use these in my laboratory for working with ultra-centrifuges (although mine say Beckman and not Park Tool.)
