but we can throw down if you’re going to want to throw down.
My gloves are on the ice. =)
First of all, granderson played 6 games in 04, and 45 or so in 05. Sizemore played 47 in 04, and went full time in 05.
Well, yeah, that was MY point. Up to this point Sizemore has had the better career (if for no other reason than he’s played more games). Granderson just started getting attention last year due to his breakout (possibly “career” season). Hence Sizemore gets more attention/praise.
Yes a base hit is better, but part of your “nothing happens” is that the hitter doesn’t ground into a double play.
Is hitting into a double play REALLY a concern for Granderson? My guess is that with a guy on, he’s “going for the downs” too often. Granderson has a BIG swing. With a guy on base, there’s MORE gaps in the infield to hit ground balls through.
You knock Granderson’s OBP, ok fine, and then say that scoring 122 runs is due to the lineup.
How many runs would a slower guy with an OBP of .420 score on that team? Note: The Tigers lineup is VERY impressive … only 2 guys struck out more than 100 times … Inge and Granderson … and outside of Magglio they don’t hit in many double plays.
In many situations, triples are like “homers” in that they are essentially “automatic runs” (a plus for Granderson). But, look at all the doubles the Tigers’ hitters hit. As I said, Granderson could be on first base, and STILL score. I just want to see him on base MORE, even at the expense of some extra base hits. Granted it will get less attention and MVP votes from the media, but could make the Tigers even better.
Granderson sucked so bad at getting on base he was only 4th in total bases last season in the AL.
The total bases stat really comes into play when the batter is up with 2 outs (or with runners on). If he gets a lot of extra base hits with 2 outs, THAT’s important. But, when you look up the stats/averages for runs scored by base position and outs, a lead-off single/walk is often as good as a lead-off double, and a lead-off double is often as good as a leadoff triple, etc. It would be very interesting to see Granderson’s stats for the different situation (i.e., # of outs) hitting. It might make his season even MORE impressive (if possible). Granderson’s WARP is 10, that’s pretty darn good.
I’m not addressing anything about Sizemore, because I too feel he is over-rated. I think he gets a lot of attention because he looks good in the uniform.
Don’t get me wrong, I’m a speed freak, I’ll take the guy that can stretch the defense every time (unless he’s just dumb on the bases). Granderson sorta reminds me of Willie McGee, which won the 85 MVP with a similar style. Rickey Henderson was the greatest run scorer in history. He was fast. But, the stats geeks have done a decent job at showing how even the fastest guy might just get you all that many more runs than an average speed, quality base runner. Henderson scored A LOT of runs because he walked A LOT and played on teams with serious RBI guys (and vice versa). What that means is that Granderson will likely score A LOT of runs with the Tigers lineup provided he gets on base (any base) … which is why I am making the points I am making. OBP at the top of the lineup (i.e., in front of the best hitters) is paramount.
But, hearing Granderson talk (when he does, he seems like a quiet guy), and seeing his work ethic, I would anticipate that cutting down on strikeouts is a priority for him, and given his age and the team he plays for, he better get used to the attention and the All-Star game.
I’m not gonna get all tingly about Sizemore until he (at least) goes 30-100 for a meat of the order guy.
