Ok, the trigger is getting pulled on one of these framesets for myself but am on the fence about which one. Everything I read about both frames seem to be nothing but great reviews so I’m kinda wondering if it’s worth the extra coin to go with the 118 instead of the 117 or if the 117 is the way to go.
If I go with the 117 I’ll be running the PRO Missle Alloy cockpit
Both will be built out with
di2
TRP Spyre mechanical calipers
Enduro xd-15 ceramic bottom bracket
Rotor Cranks (undecided on the model at the moment)
Stan’s Avion wheelset with Enduro xd-15 ceramic bearings and SRAM xg1190 cassette
di2
Thanks boys and girls
How much is 3 or 4 watts and the aesthetics of an exposed cable worth to you ?
di2
I presume cable exposure will be almost identical between the 2 when I’m done with the builds.
I’m really just curious if there are major performance benefits to be had with the 118 over the 117
di2
118 you won’t see any cable. 117 you will see a cable on the front. Kind of like a Cervelo P Series
I don’t think Argon has released its aero data but I would peg it at 3 or 4 watts.
Check the stack and reach numbers of the two bikes. I don’t think they are the same.
Builds will not be identical since 118 has a proprietary cockpit
di2
Stack and reach is technically different but seems like they can be set up PRETTY similar to one another with use of spacers as well as how you mount the base bar. The cockpit on the 118 is proprietary but the base bar appears to be designed to run as a drop or a rise and the aero bars offer up to 70mm of spacer availability with the ability to pivot the extensions though I’m not sure what degree range they have.
So to your question, the difference will be aesthetics of cables. The 118 will have no visible cables, the 117 will.
There will be a 3-4 watts aero difference overall
Maybe I’m shallow or anal or both, but I HATE exposed cables on bikes. I’d go for the 118.
I’m shallow too and really don’t like how “basic†the fork shape is on the 117. However I’m sure I can find a suitable replacement if I really need to satisfy my vanity if I grab the 117 over the 118
As someone stated above, the 117 and 118 are vastly different. IMO the 117 and 119 are similar in geometry. Perhaps you can fit the 118, but just be aware of the difference. Check the specs if you haven’t already. We have all 3 bikes in our shop. They are all amazing bikes and very light while a great value for the money.
what is the price difference when all built up ?
Really it’ll just be the price difference of the frames. All parts other than brake levers and bar end shifters are in the box ready to get installed.
The 117 I’ll have to order the pro missile alloy cockpit but that’s the only part one frame would need over the other
