As I’ve worked to get better at swimming (still not good but getting better), one of the things I recently noticed was that when I breathe to my right side, I always initiate my left arm movement/start pulling way too soon. This does not happen if my face is in the water. My stroke is longer, smoother and more controlled then.
I assume this is bad balance, need to drive my hip forward/down better, work on my core…?
As a point of info, I almost exclusively breathe to the right and I’m sure that has caused imbalances in my stroke.
Any tips on how to make this better/fix? I can feel the difference for the better in my stroke when I wear a snorkel or do breath control sets. It only happens when I take a breath, which ya know I’ll need to do from time to time while swimming.
Thanks in advance.
I notice this same problem when I video myself. There are people here more qualified than I to offer advice, so trust them over me. I’ll just say that in my experience, I think part of the problem comes from a tendency to breathe a hair too late, not turn my neck enough, and therefore over-rotate. When taking a breath, my tendency is to just rotate my body without turning my neck much at all, which results in over-rotation and imbalance. The body imbalance throws off the timing of my left arm pull.
Like you, I breathe to the right. If I concentrate on turning my neck just a hair more and slightly quicker/ earlier to avoid over-rotating, I find it is easier to have a more patient left arm lead. I also sometimes try to think of my right arm as pulling me into the breath.
When I watch myself on video taken with the camera underwater at the end of the lane, I can tell I’m doing it better when my left arm stays still at extension and the left-arm catch is more directly toward the back of the pool. When I’m not doing it as well, my lead arm kind of waves around in front of me sliding toward the midline prior to starting the catch. Also, my right leg comes out to the side more, probably trying to stabilize me as I over-rotate.
That’s my amateur analysis. Listen to the coaches.
