I am able to find the definitions for TSS (training stress score). But, I can’t find any where what the actual value means. what does the value represent? My last marathon was 405 rTSS, and two easy runs this week were 45, and 69. I can grasp that the marathon was a harder effort, and created more stress than the couple 4-5 mile runs, haha.
But, I didn’t know if someone could shed some light on what the value actually represents?
Thanks for the articles. I read them, and my question is not how the number is determined - as much as - how do i use the number. If a 90 minute run - gives me a value of 110 - does that 110 - correlate to anything concrete? a specific rest interval? or is this a historical value i can use to compare my training over time (i.e. 90 min run @ 6:45 pace -110 rTSS, 6 months later same run only gives value of 102)?
It’s not really meant to compare one workout to another. An hour a 6:45 today will net you the same number as an hour at 6:45 6 months from now (unless your threshold pace has changed)
TSS, which is modeled after Dr. Eric Bannister’s heart rate-based training impulse (TRIMPS), takes into account both the intensity (i.e., IF) and the duration of each training session, and might be best viewed as a predictor of the amount of glycogen utilized in each workout. Thus, a very high TSS resulting from a single race or training session can be used an indicator that one or more days should be scheduled. While individuals will tend to differ in how much training they can tolerate, depending on their training background, natural abilities, etc., the following scale can be used as an approximate guide:
TSS less than 150 - low (recovery generally complete by following day)150-300 - medium (some residual fatigue may be present the next day, but gone by 2nd day)300-450 - high (some residual fatigue may be present even after 2 days)Greater than 450 - very high (residual fatigue lasting several days likely)
As well, the cumulative TSS per week or per month can be used help identify the maximum intensity and volume of training that still leads to improvements, rather than overtraining.
100 TSS points is mathematically the same lactate dose in terms of concentration x time as a 1 hour max workout. A case can be made that lactate dose is what causes training effect, or if it isn’t exactly lactate dose it is something that tracks relatively closely to it.
So this way you can kinda of equilibrate long hard workouts with shorter hard workouts. I say kinda because it isn’t totally the same. You don’t get the same training effect from a 60 minute workout at 1005 as you get from a 2 hour workout at 71% even though the TSS would be the same. But over the course of an entire season, they are similar enough to work with.
As stated it goes hand in hand with performance modeling or the PMC chart. The idea there is that your fitness correlates with your long term moving average of training, IIRC the default weighting of the PMC approximates a 84 day moving average. Your fatigue detracts from your performance on the other hand and it is a function of your short term average training load, the default PMC weighting approximates your 13 day moving average of training load.
Now that’s more like it.
Hey anyone, what’s the difference between 68 TSS and 74 TSS? 8 ml of hope or suffering? I can’t remember what it means, help me out here. I want to drink something that replaces the TSS I’m leaking.
I just scored 93 TSS, did I make the playoffs?
My score for a race was 301, would I have won if I scored 305? How come I’m not dead after 299?
Eric got it about right in the general sense anyway. Just understand, and this is important, if you show up on race day with a pile-o-Pesos when the specific physiological demands laid on by course and competitor is for Kroner and/or good ole USD, you’re a bit screwed. The exchange rate can make all the difference.
It doesn’t work like a bank account. You can’t assume that because you have paid in $5000 that you can withdraw $5000 with interest.
It’s a bit like a Ponzi scheme, some early investors might get some reasonable return, but when you try to get all your money out you end up calling in the FBI.
Remember the advise given when you invest in stocks and shares,
'past performance is no guarantee of future results".
Beware mathematical models and algorithms - they didn’t stop the banking crash but they may well have caused it.
Dare I ask, but can you write this in plain English. Thanks
I’ve been using the TSS concept for about 3 months now and I would describe it as a barometer for your training.
YOu should go back 2-3 months and look at your training and enter it in training peaks to get a feel for what you have been doing up to this point.
Once you have established a base level for your training it becomes a balancing act to adjust training load based on your freshness and fatigue level. Use it to build and taper depending on your schedule or season.
Like I said it is a barometer and you need to monitor it regularly and adjust your training accordingly.
It’s a way to quantify training stress and you can use it to monitor your overall training load. I find it most useful for making sure the training load is increasing, but not too rapidly. After you use it a while, you start to learn what type of load you handle well, what is a big training load for you, how quickly you can ramp up the training load before a lot of fatigue sets in, etc.
It’s not a perfect system, but it is useful. Use it as a guide, but don’t get too hung up on it. It’s not the be all end all of training and racing.
Thanks - about 80% of the comments have been helpful. I’ve had some break out races this past season, and want to focus my training to see how much i can improve. I think moving to training peaks, and monitoring my workout load over the course of the season - could be very beneficial.
You might want to start by figuring out your threshold pace and updating TrainingPeaks. That way you’ll get more accurate scores to help plan the rest of your training and recovery.
