Anyone use Token Ninja or Origin8 Revolvr BB90 bottom bracket?
Any feedback on either of these. I was going to grab the Token version but the install tool is out of stock everywhere. After a little searching I found the Origin8 version.
https://token.synfinityup.com/Bottom-Bracket-for-BB90-BB95-Trek-Frame-with-SRAM-GXP-Cranks_p_444.html
https://origin8.bike/collections/bottom-brackets/products/revolvr-bb90-95-thread-together-bottom-bracket
I’m using a Token Ninja in my Speed Concept.
No problems with it yet (only fitted at the end of last season, and just kicked in racing for this year).
Fits solidly, and if anything has stiffened up the feel to the bb area.
Like you found the bb’s are available but fitting tools are harder to find, and you do need it.
I bought them as a pair off ebay via a shop in Taiwan (cycling boss)
Confession. My first bike job was for token many moons ago.
They are a brand whose background is bearings. I love, love any of their bearing products, headsets, bb, hubs and they are my go to for all my bikes. I. Even specd their hubs on some culprit branded wheels.
Definitely go with token
Let me look into tool if you can’t find one.
Joshua
Thanks. I know Token has a good reputation. Interestingly, the Origin8 version looks to use Token bearings but I guess it’s their own version of the threaded sleeve. Or is Origin8 affiliated with Token in some way?
No but interesting… both of them! I’ve traditionally used the standard press in bearings in my Trek SC.
This sort of threaded body BB might solve creaking and stiffen up the BB I’d imagine. If the bearings are good looks like a home run to me!
That’s the intent. Though I’ve had a Gen1 SC for about 10 years and never had a BB issue, I’m building up a new to me Gen2 and figured it can’t hurt to go with this as a preventative option.
Origin cooperates with token is what the token G.M told me today.
So likely very similar results.
K. So likely the same bearings. I think I’d still prefer the Token version.
did you already buy the bb
I’m going to token hq tomorrow if you need any help let me know
I haven’t bought one yet because I can’t find the install tool.
Where are you located and how urgently do you need? I’m flying to California July 3, if in the states can post to you.
Why don’t you buy a Wheels Manufacturing bottom bracket?
PM sent. I’m in no rush. The bike currently has a standard GXP BB but I’d like to switch just as a sort of preventative maintenance.
I hadn’t come across that one. All I’m seeing is bearings on their page though - https://wheelsmfg.com/bottom-brackets/trek-bb90-95.html
Look at the BB86/92 bottom brackets.
What use are they to the OP? BB86/92 or PF30 are not relevant.
Maybe if you didnt talk in riddles it would help.
I was also wondering if he knows something no one else knows or if he’s just trolling the OP.
I made a mistake. I thought that BB86/92 would also fit BB90, sorry.
I told you on another thread BB’s do my head in nowadays, seem to take ages to check all the specs and the specifics of the frame that seem to change each year. So heartening to me that occasionally it happens to others too :wink:
Curious how your Token Ninja is holding up in your SC…
I’ve used various press in aftermarkets (angular, ceramic, abec-5) and all of them after a season or two the non-drive side turns to garbage. Even if I pull seals, clean it out and regrease them too. For whatever reason the drive side bearing all seem to be relatively fine… maybe a downside for GXP BB/cranks?
I digress still looking for a better solution for my BB90.
