Anyone use these Pista track cranks Veulta Pista
I have SA 4710 narrow crank 170mm with 1x setup but want to try 165mm crank arm length and doesn’t seem they were made that short
So I’m Looking to buy a 165mm narrow crank for a newly acquired P3 frame
I see used Campy Pista cranks on EBay for around $300
Wondering if anyone has experience with this crank which is considerably less expensive
https://www.vueltausa.com/...t-46t-165-170mm.html
Not sure about those cranks, but Miche Pistard Air will get you 138mm Q Factor using a Shimano Hollowtech (24mm) BB
Thank you for the info
Any experience with this one?
Seems narrower, lighter and less expensive but perhaps not as aero. But I need larger chainring on either crank as I’m using it for 1x on the road
https://www.probikekit.com/bicycle-cranksets-and-chainrings/miche-primato-advanced-track-chainset-silver/11839782.html?affil=thggpsad&switchcurrency=USD&shippingcountry=US&variation=11839783&&lid=92700006698385531&ds_s_kwgid=58700000369675018&ds_e_product_group_id=90116285551&ds_e_product_store_id=&ds_e_ad_type=pla&ds_s_inventory_feed_id=97700000001003124&gclid=Cj0KCQiAyp7yBRCwARIsABfQsnRRQq_OEJB_8S0JPI9o6XsnKrUwszDb5bf3KaFn72psYt2-vVCaQ6kaAk38EALw_wcB&gclsrc=aw.ds
Sorry, I haven’t measured the Primatos. I do suspect the Miche Pistard (not Air) version is identical to the Pistard Air apart from not having an aero spider section, which would make the Q Factor the same as the Air, but again haven’t actually measured a set so don’t know for sure.
