Anyone sell adjustable tilt blocks?
I have a Trinity, the whole Tririg thing is a non starter.
I see all the hardware out there to tilt cockpit by some finite amount. Usually requiring buying more than one thing.
Anyone sell something that tilts 0-20 deg for the extensions?
I’d like to try a more affordable tilt option with existing hardwares to try out some fit coords with the Notio before deciding on anything really expensive for the cockpit that is possibly more fixed. As some seem to only toss you 15 deg, 10 deg, or 20 deg. Etc…
Wattshop sells one
https://www.shopforwatts.co.uk/collections/anemoi/products/anemoi-adjustable-angled-riser
I have one designed for Culprit which I am waiting on riding samples for. Will pre sell this summer for winter delivery.
No matter, you have options for pad only tilt, or use your existing risers and change to my tilt which offers 22.2 attachment version, etc.
No matter, its cheaper than a new bar, but not “cheap” per say.
hope that helps
Joshua
Wattshop sells one
hope that helps
Joshua
Thanks!
Watching for their stock back come August.
My reason is I measure with a level the Trinity (all of them) cock the damn pole clamps about a full 1 to 1.5 degrees. So I am at more like 13.75 degrees and 8cm instead of 15deg and 10cm.
https://www.revolverwheels.co.uk/shop/components-accessories/20-degree-arm-rest-wedges/
