I have a pretty tight aerobar set-up with my S-bend aerobars rotated inward. This does not leave room for the Xlab Torpedo system (which I would have loved to have) so I went with Profile Design HC aero bottle mount with computer mount (not their bottle, just the mount). I originally had the device set up standard with the bottle facing forward. Because my aerobars are turned inward, the bottle BARELY fit, had to be a smaller bottle and had to be shoved in with pressure halfway forcing it out of the cage. The other downfall was the computer mount stuck back right over my stem, which made it pretty tough to comfortably read my data.
Today I decided to switch everything around and at first glance it was glorious. I had perfect access to my 910 XT display, my water bottle fit better than ever since it was not receiving pressure from my aero bars, and my hands had plenty of room. My problem arose during my first ride. Since the bottle is facing slightly downward, when I hit a small pothole I instantly launched my bottle. When I rode over a cobblestone section, my bottle came about 50% out. I had to slightly move my bottle up about 10 times during a 40 mile ride.
I currently have the XLAB Torpedo cage mounted on this set-up and it was set up pretty loose in order to allow my previous bottle position with the bottle BARELY fitting facing forwards. I could tell this was a bit of a problem during the ride because there was quite a bit of chatter. I have since snugged up the bolts and it appears the fit is much better… though still possibly not strong enough to avoid a launch if I hit a large bump… Is it that big if I launch a bottle? Not during training, but during an Ironman it could be very costly.
I am Considering keeping the same set-up, though replacing the Torpedo cage with the Gorilla cage. Has anyone ever used a Gorilla cage up front? The packaging clearly labels the torpedo for use in BTA set-ups while the Gorilla is designed for rear hydration systems. Will I have a big problem putting the Gorilla cage up front? Will I receive a huge aero penalty? Will it even fit properly? Do you think it will solve my launching bottle dilemma? Since it is a spendy cage, I want to seek some advice before I try it out.
Here are a couple pictures of my current set-up.
http://img.photobucket.com/albums/v236/Neopian_Knights/BTA2_zpsf2afdd3d.jpg
http://img.photobucket.com/albums/v236/Neopian_Knights/BTA1_zps844384f8.jpg
