Fairly certain after riding a loop of it that it’s about momentum managment so thought I’d use the PT w/disc cover…
Anyone else do the same ?
As opposed to without the disc cover? I think the advantage of the disc cover is minimal. Most of the course is highly shielded from the wind but I certainly don’t see how it could hurt.
Sure, I would go with it but then I would probably always go with it except when I couldn’t (eg Kona) or maybe IMC on a very windy day.
Thanks, Chris
You won’t see a lot of disks at LS, but you will see them. The course does not present a lot of opportunities where a disk would make a difference versus an 808. Run what you brung, because it certainly won’t “hurt” you per se.
