I currently don’t have any fit issues… I guess it’s just out of curiosity for more power.
Online crank arm length reccomendation algorithms put my appropriate crank arm length at anywhere from 205 to 215mm. Of course, most of those algorithms are linear, like L = x(inseam) + y, and not based on a logarithmic scale. Since I’m a but of an outlier anyway, I wonder about the accuracy of such predictions on the extreme ends of the distribution.
Tom, you’re pretty knowledgeable about time trialing and time trialists… Do you know what crank length some of the taller TT specialists use? I.e. David Millar, Bradley Wiggins and Gustav Larsson? Larsson has almost identical measurements to me if I remember correctly.
Well…this guy isn’t exactly a “TT specialist” (unless you consider the bike leg of an IM to be an extra-long TT) but IIRC he’s about 6’3" (4"?) with fairly long legs and he just went DOWN to 172.5s and is thinking about trying even SHORTER cranks
Here’s my take on the whole thing, and I’m sure I’ll get blasted by the “proportionality” folks…but there have been plenty of discussion here on ST about crank lengths and power production and the fact is that most folks can accommodate a VERY wide range of crank lengths without any appreciable effect on their power output.
Most people get caught up in the fact that the crank arm is a lever…yet lose sight of the fact that it is only ONE lever (well, 2 actually…one on each side) that is a part of basically a series of “continuous levers” (i.e. the gears) that make up the total “gain” between the force/pedal speed at the foot to the force/speed at the tire/ground interface.
I look at it this way…your legs “want” to apply force in a fairly linear direction…that’s just how they’re “designed”. The crankset is a fairly efficient mechanism for converting this fairly linear force application to a circular motion. As such, the “power stroke” of the pedal cycle only accounts for ~1/4 to 1/3 of the total pedal circle, while the rest of it is really just a way to get the foot back into the “start” position for pushing down again. Now, when one varies crank lengths, IMHO it’s VERY important to ALSO move ones saddle so that the orientation of ones leg relative to the pedal is the same. In other words, if you move from a 170mm crank to a 175mm crank, for example, you should move your seat AND your bars forward by 5mm as well.
Here’s another way of looking at it. Draw out circles that would be inscribed by crankarms of, let’s say, 170mm, 175mm, 180mm, and 200mm. Now, instead of making them concentric, make it so that they are tangent to each other along the horizontal direction. Now, look at the portion of each circle that’s +/- 1/6 of the circles, centered on that tangent point. There’s not a very large difference in the paths, is there? That’s where the power is being produced.
So…to sum up for now…if you don’t have any “fit” issues that could be alleviated by going to longer cranks (I actually can’t think of any), then I don’t see the point. If it’s “leverage” you’re looking for…well, as I said above, that’s only one part of the total gain of the system, and it’s probably better for you to just use different gearing…it does the same thing. One thing you alluded to above that you need to be concerned with is that going to longer cranks will necessarily speed up your tangential foot velocity at the same cadence (since your feet would be following a larger circle in the same time)…so, going to larger cranks would tend to slow your cadence…which again might require gearing changes. If you don’t feel your cadence is too high as it is, then again, what’s the point?
One last thing you might want to consider is what effects going to longer cranks would have on your position if you happen to need to comply with UCI requirements for some events. Being as tall as you are, you’re already going to be constrained with your bar reach. If you put on longer cranks, in order to keep the orientation of your leg to the pedal in the “power stroke” the same, this will mean moving your entire body forward relative to the BB. That could end up putting beyond the UCI bar end limit and/or make your front end REALLY “cramped”. In fact, that right there is an argument for experimenting with SHORTER cranks for taller riders
Not to mention the fact that shorter cranks tend to allow folks to ride with their torso more “horizontal” without excessively tightening up the thigh/torso angle at the top of the stroke. Longer cranks will do the opposite and you may need to raise your front end to prevent being “cramped” at the top of the stroke.
Anyway…just my 2 centavos…flame away
