Anybody have any tips on any sprays or coatings that I can apply to the bolts for my aerobar pads to prevent them from rusting?
I just got my bike back from the LBS after rusting through the bolts that hold the pads down - they were so corroded that they had to be drilled out because the hex wrench hole couldn’t grip any more.
I use a special sweat cover for my TT bike on the trainer, but the aerobar pads remain exposed, and they’re taking a beating as I sweat a ton on the trainer. The sweat is seeping through the pads and rusting the bolts beneath the pads.
A big towel over the aerobar pads does work, but then covers up the clear window that displays my Garmin on the stem, which is important to me to be able to see.
Any good coatings or spray on things that can prevent these bolts from rusting prematurely or at least slow down the rust?
I have something better - mcmaster.com. Buy stainless steel bolts. One of the cheapest and most useful upgrades you can make to your bike. The fact that stainless bolts are not standard industry wide continues to baffle me. With all the focus on carbon this and that, it’d be a marginal cost increase to make bikes substantively better.
I don’t know about a bike specific product, but Break Free CLP (machine gun oil) which is available at any Bass Pro Shop will do a good job at preventing it. If you don’t have one of those close by you can always go to dicks and get Break Free LP, which has all the lubrication and preventive properties but no solvents to eliminate existing rust. If you don’t mind grease, I would think simple vaseline would be ok, but Hoppes long term storage gun grease will absolutley prevent rust without have to reapply as frequently. I have seen tests with all these product on sheet metal left ouside for 6 months. The Break Free barely had any, the Hoppes had none where it was streaked. The unprotected sheet metal looked completely red.
I’ve never done it, but I’ve heard of putting silicon caulk on the heads of exposed bolts, especially if they are of the “tighten and forget” type. If you need to access the bolt head, you can usually ( pick the caulk out. I think this was also a trick for seat post binder bolts so that a thief can’t quickly pinch your seat post and saddle when the bike is locked up at your coffee shop.
I get a Qtip and grease and swab a little inside the hex hole. If it’s the threads rusting that won’t help and I wouldn’t grease the threads. Ziploc bag and wash cloth over each armrest during trainer session. Clean and dry them regularly or at least uncover them after you’ve sweated them up good and make sure they don’t sit in moisture. Depending on the bolt, you can upgrade to nonrusting material, 316 or Ti.
I have a hard time finding out exactly what the right bolt size is. I’ve tried them before, but even a mm of mis-sizing = fail. (I did this for the limiter screws on the Cervelo rear wheel cutout, which didn’t work well.)
Thanks
Clear fingernail polish.
We may have a winner here.
Have you actaully tried this, or is this a theoretical guess?
Thanks for the link. Now, the question is what size bolts are most aerobar bolts? Only way I have ever done it is by going to home depot with the old in hand to compare.
Someone from ST should start a cottage industry of replacing all the bike bolts and other parts with stainless steel stuff. I’ve heard arguments about how the strength/grip of them isn’t as good, but I think those are moot compared to the mild wimpy human forces we exert on these bolts. It’s not like some bike hydraulic machine is subjecting them to tons of forces - we’re pretty wimpy as humans.
I would love to change ALL my bolts and parts to stainless steel - it’s just I have a hard time matching up all the parts, having mis-ordered them before.
I’ll second Rappstar on this one - stainless steel - check out www.loosescrews.com - cycling specific retailer. Replaced hex screws on stems and aerobars 3-4 years ago and they still look like new - even on the trainer bike. Good luck.
The problem with stainless steel fasteners is that they can cause galvanic corrosion to whatever they are fastened to, including various aluminum alloys and carbon steels.
Does help for rust. We used to fill our stem and der bolts with silicone to deter thieves. Worked, they’d just take the whole bike but never lost my bars!
Not quite the same, but I used clear nail polish as a lacquer over my Union Jack stickers on my top tube to much success. The stickers were not the durable coated type to begin with, more like a paper. The nail polish has been on for over 6 years now and they still look new.
The problem with stainless steel or titanium is dissimilar metal corrosion
I’d recommend installing bolts with Boe-shield; good enough for the Boeing jets, good enough for bikes
