Any feedback on Figmo or Edge frames/products?
Not that I am in any position to purchase anything at this time, but I saw someone selling frames under the Edge/Figmo brand and did a search on here and couldn’t find anything on it. Just trying to see if anyone had any experience (good or bad) with this brand. I cut and pasted the text (I edited it a little):
“As a European brand, Edge/Figmo is not yet well known in the US. However, I can assure you that this frameset is made in the SAME factory as those listed and frequently sold at TWICE this amount.
This frame has ALL of the details you are looking for in a FAST TT / Time Trial / Triathlon Frame including a DEEP rear wheel cutout and extra tall one-piece seat mast for unmatched aerodynamics, optimized variable shaped rear seat stays for a “comfy” ride and a frame that has been custom built through the results of extensive wind tunnel testing. This frameset has all of the advances of the much more well-known “name brand” bikes that are frequently sold in overpriced bicycle stores throughout the country.
We have two sizes for you to choose from here…the Medium frameset has a 540mm (54cm) top tube and the Large has a 555mm (55.5cm) tob tube. You will notice that this frameset looks VERY MUCH like the new line of other “name brand” framesets!! The 54cm top tube should fit heights from 5’5” to 5’10", and the 55.5cm should fit heights 5’10" to 6’2". There is NO DETAIL spared on this bike (other than the $1,000 decal that the “name brands” charge you!!)
Other Features:
  • Constantly varying tube sections and optimized shapes throughout, for increased torsional rigidity and bottom bracket stiffness
  • Semi-sloping top tube for a stiffer main triangle
  • Proportionally scaled tube and junction profiles for consistent ride quality and superior stiffness
  • Bullet-Proof bottom bracket and chainstays for power transfer
  • External cable routing
  • Semi-integrated headset for a low profile
  • Replaceable derailleur hanger
  • Perfectly sculpted seatstays for dampening the vibration for a cleaner more comfortable ride"
Can you post some links to pictures/info on frame?
interesting wheel …
http://www.edge-design.com.tw/upload/product/WH078-R.jpg
http://www.edge-design.com.tw/html/product/index.aspx
Here is what I found through a google search.
They certainly have many items I would be interested in purchasing. How do you buy the items? Do they allow direct purchasing?
