Another Tire Pressure Question (I mean REALLY EXCITING Tire Pressure Question)
Tell me if my rationale makes sense:
I have been riding on either Michelin ProRace or Conti Attack/Force tires. I am happy with both. I weigh about 200 pounds and usually have my pressure at about 110r/105-110f.
I am doing two 1/2 IMs and IMMoo this year. I was considering going to a Vredestein Fortezza Tricomp because of the higher max pressure (145 psi). My thought is that I will chck pressure at 6AM. But my bike will be sitting and being ridden in the sun/warmth for many hours. It will be 20-30 degrees warmer at 2pm. I know the 10 degrees = 2 psi rule. But with the higher max tire, I can just consider the likely temp. rise and pump it up to the desired pressure and still have a significant buffer if the temp get much higher than I predicted 6-8 hours later.
Or do I just stick with the Contis or Michelins and figure that I will be fine even if I go over the 120 or 116 maximums (respectively). I do not want to underinflate because of my weight.
Thanks for any and all comments.
I ahve been contemplating this for quite some time for my TT bike so I do not have any experience with the tires I am about to suggest. Also, be forewarned that what follows probably will not sit too well with the purist/tubular crowd (yes - I have ridden/raced tubulars and may do so again). So, if tire pressure is a concern and you are running clinchers, why not consider Tuffo tubular/clinchers which can be pumped up to 220 psi (assuming your pump goes that high)? I have not been able to find much in the way of feedback and there have only been a couple of reviews from riders using the Tuffo tires (USCF racing). Although everyone agreed that the Tuffo’s are not a good choice for regular training/riding, each of them was unanimous in opinion and offered good feedback about things like good to superior grip in corners, smooth roll, and a nice ride when pumped up to 140-160-180 psi!
Michael
I used to pump my Pro-Race tires to 140 all of the time and had absolutly no problems ever. All that I got from that was a rough ride. I find that there is really no noticeable difference in rolling resistance between 110 and 140psi for those tires.
I wouldn’t worry at all about overinflation from the temp changing from morning to afternoon. To me this is a non-issue.
jaretj
Make sure your rims are rated to handle that much tire pressure— Not all clincher rimes can go above 130 PSI.
THIS IS AN EXCITING QUESTION!!!
I’ve been riding on Michelin Carbons and use the Pro Race for my actual races. I usually run 120-125psi because it seems like they roll faster in that range. I typically pump up the tires to 115ish early in the morning, and they ended up at 122 at race time. I did this the day before the GCT just to see. Temps were around 70ish in the morning and 91 and sunny when I checked them. I did run my Carbons up to 135 or so, but it just seemed to get a lot harsher rather than improving the rolling speed. There’s a world of difference between 105psi and 120psi though. I used to run HiLite SupercompHD 700x18s at 135psi…harsh but fast!
I am working on an experimental setup to test rolling resistance of tires, so I might have some actual data sometime soon. Of course I’d have to stop training for a few days and finish welding…
Why are you racing in training wheels (clinchers)? You should get race wheels (tubulars) and that way you can pump them to close to 180psi.
Was that a smartass answer Smartasscoach?
Presuming not, financial considerations are the reason. I am just not good enough to warrant the expense - and I really cannot afford them anyway.
Buy a beam bike and there is no such thing as a “harsh ride”. So pump the tires to 160 and GO!!!
